Register | FAQ's | New Posts | Today's Posts | Extras |
» dryer element heats hot on every temp level |
![]() Model Number: teds840jq2 Brand: Estate Age: More than 10 years
![]() The dryer was tripping the breaker and now it just heats glowing hot on each temp cycle until i assume the thermal overload shut it down. After it cools a bit it starts heating all over again. What up with this? Thanks. Related Models |
See inside of your appliance - diagrams and part photos for virtually every model.![]() powered by AppliancePartsPros.com |
![]() Here are your parts
Replacement parts for WHIRLPOOL TEDS840JQ2 DRYER | AppliancePartsPros.com See the attachment for the wiring diagram. You may have a grounded element. Check the heating coil. Unplug the unit and both wires to the coil. Check it with a meter, should be around 10 to 12 ohms. Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on all temperature settings.
__________________
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Oven heats up to Temp, but wont light back up to keep at temp | Pooler | Oven Repair (including Ranges and Cooktops) | 1 | 05-06-2014 07:46 AM |
Oven Heats up but does not keep temp. | blybtnlint | Oven Repair (including Ranges and Cooktops) | 0 | 04-30-2011 03:12 PM |
Oven heats up and reaches temp and then stays off | mikkidee | Oven Repair (including Ranges and Cooktops) | 0 | 09-17-2009 05:07 PM |
Jenn air oven heats, but not to correct temp | miketesting | Oven Repair (including Ranges and Cooktops) | 0 | 07-14-2008 05:42 AM |
Oven lights and heats to Temp but goes out immediately!! | jomo | Oven Repair (including Ranges and Cooktops) | 0 | 08-31-2007 09:49 AM |
