| » Drying continue drying in auto cyclr |
Model Number: REX5634KQ1 Brand: Roper Age: 5 - 10 years
Dryer doesn't stop in Auto Sense or Timed Dry, I have to stop it manually by opening the dryer door or turning the control knob to the off position. Please Help..... I really don't want to buy a new dryer. I have technical background but not with appliances.
Model REX5634KQ1 Here is a wiring diagram https://www.servicematters.com/docs/...%208528187.pdf You probably just need a new timer Best way to check is with a meter. Measure across the timer motor with the unit running. If you get 240 volts and the timer is not advancing then it is shot. BE VERY CAREFUL 240 VOLTS IS LETHAL OR Alternatively unplug the machine, unplug one of the motor wires at the timer, measure the timer for resistance, if it is open, the timer is shot. Note this just checks the motor unlike the earlier test which checks the motor and the timer gears. OR Just order a timer, odds are very high that this is the problem. As long as everything else is OK.
__________________
| Display Modes | |
| not drying | rbourn | Dryer Repair | 1 | 09-24-2009 03:06 AM |
| Upper Drying Cabinet Not Drying | Slate0 | Dryer Repair | 0 | 02-17-2009 07:02 AM |
| Dryer will not heat during timed drying; will heat for short time while auto drying | mg13nj | Dryer Repair | 11 | 11-11-2008 03:50 PM |
| auto sensor drying issues | wlvrne26 | Dryer Repair | 1 | 11-10-2008 05:05 AM |
| Amana ALE866SAW not auto drying | murdstone | Washer Repair | 1 | 01-09-2008 01:39 PM |
