Discuss
How can I be sure there is no gas leak from dryer connections?
 in
Dryer Repair
After moving into my new home, when I connected the dryer, one head of the gas connector (to the house
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » How can I be sure there is no gas leak from dryer connections?
  #1 (permalink)
Old 02-26-2009, 10:50 AM
Junior Member
yzhong is on a distinguished road
Default How can I be sure there is no gas leak from dryer connections?
Model Number: LG9501XTN1   Brand: Whirlpool   Age: More than 10 years
After moving into my new home, when I connected the dryer, one head of the gas connector (to the house gas outlet) was broken, so I bought a new gas connector (Brass Craft Coated Stainless Steel Gas Connector, OD Tube, 48, Item # 2661311431.6). Following what kind of sealing material being used before, I put Block Seal paste on the connection of male adaptor to the house gas outlet, and white seal tape to all other connections, including two ball joint heads of the gas connector, the gas connector to the male adaptor (to house gas outlet) and to dryer gas inlet. After open the house gas outlet valve, I put liquid detergent to all external gas connections and did not find any leaks. Now the dryer works fine for 19 days. But occasionally I smell gas, but more times I did not smell anything. My wife has the same feeling. The dryer is in the basement laundry room. The basement windows are always closed due to winter, only the door was open several times a day. So basically the environment is quite sealed. If there is gas leak, the smell should accumulate and become stronger. But we do not feel it. I consider re-connecting all connections with the Block Seal paste. But I am worried that I may create more leaks or even break the gas connector. How can I be sure there is no leak, or how to find where the leak is?
Thank you. Adam
Related Models
Whirlpool LG9501XTW0 Residential Dryer
Whirlpool LG9501XTW1 Residential Dryer
Whirlpool LG9521XTW0 Residential Dryer
Whirlpool LG9521XTW1 Residential Dryer
Whirlpool LG9681XWW0 Residential Dryer
Whirlpool LG9681XWW1 Residential Dryer
Whirlpool LG9701XSN0 GAS DRYER
Whirlpool LG9801XKW1 Residential Dryer
Whirlpool LG9801XMW0 Residential Dryer
Whirlpool LG9801XMW1 Residential Dryer
Whirlpool LG9801XMW2 Residential Dryer
Whirlpool LG9801XPW0 Residential Dryer
Whirlpool LG9801XPW1 Residential Dryer
Whirlpool LG9801XSW0 Residential Dryer
Whirlpool LG9806XPW0 Residential Dryer
Amana LGA10AW DRYER- GAS
Amana LGA20AW DRYER- GAS
Amana LGA30AL DRYER- GAS
Amana LGA30AW DRYER- GAS
Amana LGA50AL DRYER- GAS
Amana LGA50AW DRYER- GAS
Amana LGA60AL DRYER- GAS
Amana LGA60AW DRYER- GAS
Amana LGA80AL DRYER- GAS
Amana LGA80AW DRYER- GAS
Amana LGA90AL DRYER- GAS
Amana LGA90AW DRYER- GAS
General Electric LGB116BPA1AD Gas range
General Electric LGB116BPA1WH Gas range
General Electric LGB116BPA5WH Gas range
General Electric LGB116GPR1 Gas range
General Electric LGB116GPT1AD Gas range
General Electric LGB116GPT1WH Gas range
General Electric LGB116GPT2AD Gas range
General Electric LGB116GPT2WH Gas range
General Electric LGB116GPV1AD Gas range
General Electric LGB116GPV1WH Gas range
General Electric LGB116GPV2AD Gas range
General Electric LGB116GPV2WH Gas range
General Electric LGB126BEA1AD Gas range
General Electric LGB126BEA1WH Gas range
General Electric LGB126GER1 Gas range
General Electric LGB126GET1AD Gas range
General Electric LGB126GET1WH Gas range
General Electric LGB126GET2AD Gas range
General Electric LGB126GET2WH Gas range
General Electric LGB126GEV1AD Gas range
General Electric LGB126GEV1WH Gas range
General Electric LGB126GEV2AD Gas range
General Electric LGB126GEV2WH Gas range
General Electric LGB126GEV3AD Gas range
General Electric LGB126GEV3WH Gas range
General Electric LGB128PEB1WW Gas range
General Electric LGB128PEB6WW Gas range
General Electric LGB136GER1 Gas range
General Electric LGB146BEA1AD Gas range
General Electric LGB146BEA1WH Gas range
General Electric LGB146BEA2AD Gas range
General Electric LGB146BEA2WH Gas range
General Electric LGB146GER1 Gas range
General Electric LGB146GER2 Gas range
General Electric LGB146GET1AD Gas range
General Electric LGB146GET1WH Gas range
General Electric LGB146GET2AD Gas range
General Electric LGB146GET2WH Gas range
General Electric LGB146GEV1AD Gas range
General Electric LGB146GEV1WH Gas range
General Electric LGB146GEV2AD Gas range
General Electric LGB146GEV2WH Gas range
General Electric LGB146GEV3AD Gas range
General Electric LGB146GEV3WH Gas range
General Electric LGB146GEV4AD Gas range
General Electric LGB146GEV5AD Gas range
General Electric LGB146GEV5WH Gas range
General Electric LGB156GES1 Gas range
General Electric LGB156WEA1WW Gas range
General Electric LGB156WEA2WW Gas range
General Electric LGB156WET1WW Gas range
General Electric LGB156WET2WW Gas range
General Electric LGB156WEV1WW Gas range
General Electric LGB156WEV2WW Gas range
General Electric LGB156WEV3WW Gas range
General Electric LGB156WEV4WW Gas range
General Electric LGB156WEV5WW Gas range
General Electric LGB336GER1 Gas range
General Electric LGB336GET1AD Gas range
General Electric LGB336GET1WH Gas range
General Electric LGB336GET2AD Gas range
General Electric LGB336GET2WH Gas range
General Electric LGB336GEV1AD Gas range
General Electric LGB336GEV1WH Gas range
General Electric LGB336GEV2AD Gas range
General Electric LGB336GEV2WH Gas range
General Electric LGB336GEV3AD GAS RANGE
General Electric LGB336GEV3WH GAS RANGE
General Electric LGB346SEV1AD Gas range
General Electric LGB346SEV1WH Gas range
General Electric LGB346SEV2AD Gas range
General Electric LGB346SEV2WH Gas range
General Electric LGB356BEA1AD Gas range
General Electric LGB356BEA1WH Gas range
General Electric LGB356BEA2AD Gas range
General Electric LGB356BEA2WH Gas range
General Electric LGB356GER1 Gas range
General Electric LGB356GER2 Gas range
General Electric LGB356GET1AD Gas range
General Electric LGB356GET1WH Gas range
General Electric LGB356GET2AD Gas range
General Electric LGB356GET2WH Gas range
General Electric LGB356GEV1AD Gas range
General Electric LGB356GEV1WH Gas range
General Electric LGB356GEV2AD Gas range
General Electric LGB356GEV2WH Gas range
General Electric LGB356GEV3AD Gas range
General Electric LGB356GEV3WH Gas range
General Electric LGB356WEA1WW Gas range
General Electric LGB356WEA2WW Gas range
General Electric LGB356WEV1WW Gas range
General Electric LGB356WEV2WW Gas range
General Electric LGB356WEW1WW Gas range
  #2 (permalink)
Old 02-26-2009, 12:54 PM
TechnicianBrian's Avatar
Senior Expert
APP Volunteer
TechnicianBrian is on a distinguished road
Default
Use soap bubbles on all joints to find a leak. If it is a rather slow leak, the bubbles may not work and in that case, a combustable gas leak detector would be more accurate. Or call your gas utility and see if they can come over and use their equipment to verify there is no leak.
__________________
TechnicianBrian
TechnicianBrian.com
AllTechAppliance.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
blower connections ramcasty Heating, Ventilation, and Air Conditioning (HVAC) 2 12-28-2009 10:21 PM
Electrical Connections backnblu Refrigerator & Freezer Repair 0 12-24-2009 12:20 PM
Electrical Connections Connor Oven Repair (including Ranges and Cooktops) 0 02-28-2009 09:09 AM
New ERC connections are different than old one ccastleton Oven Repair (including Ranges and Cooktops) 3 01-08-2009 03:31 PM
Do I need to solder the connections? itstir Oven Repair (including Ranges and Cooktops) 2 05-21-2008 06:37 AM
