dego
#1 Posted : Thursday, February 26, 2009 4:05:30 AM(UTC)
dego
dryer stopped heating, replaced the heating element, but still get cold air, no heat.
i am looking at maybe replacing the thermostat, however, is there anything else i need to check and trouble shoot prior to just buying
any part?
dego
#2 Posted : Thursday, February 26, 2009 4:14:10 AM(UTC)
dego
ok guess i need to find an ohmmeter, just read other posts looking similiar to my problem.
kayakcrzy
#3 Posted : Thursday, February 26, 2009 4:24:34 AM(UTC)
kayakcrzy
You might want to flip your dryer breaker off and on a few times, to see if it has partially flipped. If not it will most likely be the thermal fuse. Tom ApplianceEducator.com
#4 Posted : Thursday, February 26, 2009 4:27:19 AM(UTC)
Here are the parts
Model LER4634EQ1
Here is the wiring diagram
https://www.servicematters.com/d...0Sheet%20-%203406688.pdf
You will see a thermal cutout on the wiring diagram in the heater circuit.
See Item 6 in Section 3
You can check this by unplugging the machine, removing the wires and shorting them together, tape them up so they cannot short to the frame and give it a try.
If now OK replace it ASAP as it is a safety device. Replace the set.
Give the interior a good clean. Also clean and check your vent system to ensure you have good air flow out the exhaust.
dego
#5 Posted : Thursday, February 26, 2009 4:28:42 AM(UTC)
dego
as in the main breaker box where all breakers are? or is there a breaker switch on the unit itself i need to locate and check?
#6 Posted : Thursday, February 26, 2009 4:30:01 AM(UTC)
Main breaker box
dego
#7 Posted : Thursday, February 26, 2009 4:58:57 AM(UTC)
dego
ok, main breaker, all is ok there. i threw the switch off and then back on.
and as, to the thermal fuse, i taped the 2 wires together and still get no heat.
as far as operating the unit runs, quiet, blows out exhaust very good, just that its cold air, like a fan set on high speed.
now , if i was to replace thermostats do i need to replace thermal fuse at same time, or should that not have a factor after thermostats are replaced?
#8 Posted : Thursday, February 26, 2009 5:49:36 AM(UTC)
Before you do that does your timer advance in Auto mode?
dego
#9 Posted : Thursday, February 26, 2009 5:59:56 AM(UTC)
dego
[/URL]
the answer i found was in this post: [url]http://forum.appliancepartspros.com/dryer-repair/24634-dryer-repair.html
after realizing the difference between the cut-off and the fuse, i taped the cut-off together and it started heating no problem.
now, i guess i need to replace both thermostats? or just the top one?
the high end thermostat has 3 prongs on it, the kits i saw on your site has 2 prongs. do i need to get these individually?
and thanks and many praises to this helpful forum, i will highly recommend this site to anyone needing help on appliances.
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
no heat from oven or broiler (Oven Repair (including Ranges and Cooktops))
by lennyag 1/5/2024 1:41:07 PM(UTC)
Dryer loud squeaking and no heat (Dryer Repair)
by hackerfam 11/2/2023 10:52:15 AM(UTC)
LG Dryer DLE2301R No Heat (Dryer Repair)
by mhess01 10/19/2023 4:56:37 PM(UTC)
No heat when assembled (Dryer Repair)
by Guest 8/16/2023 3:44:03 AM(UTC)
whirlpool PN# W10339417; no heating after replacing element (Oven Repair (including Ranges and Cooktops))
by Guest 7/13/2023 12:27:07 PM(UTC)
Whirlpool Duet Electric dryer - no heat (Dryer Repair)
by ShawnDS24 2/25/2023 9:08:24 AM(UTC)
No heat, (Dryer Repair)
by tseibring 1/8/2023 7:57:44 AM(UTC)
Brand New LG gas dryer , GAS code, no heat (Dryer Repair)
by lglad 11/24/2022 7:24:02 PM(UTC)
Gas Dryer GE GFDS355GL0MS No Heat. Ignitor is good E11 error. (Dryer Repair)
by jim.starzynski@gmail.com 7/5/2022 6:35:29 PM(UTC)
Dryer starts, does not stop, no heat (Dryer Repair)
by Guest 6/28/2022 11:03:33 AM(UTC)
Samsung Electric Range-No Heat (Oven Repair (including Ranges and Cooktops))
by Jimh64 6/27/2022 8:39:17 AM(UTC)
Samsung Dryer DV448AEP/XAC - no heat (Dryer Repair)
by mgmjtech 5/18/2022 8:22:27 PM(UTC)
heeat turns on no heat comming up through floor register (Heating, Ventilation, and Air Conditioning (HVAC))
by Guest 2/6/2022 2:57:49 PM(UTC)
LG Gas Dryer No Heat - Control Panel? (Dryer Repair)
by TomDBBills 1/29/2022 4:03:42 PM(UTC)
