Clothes Dryer
My Belt Broke And I Need To Put A New One On. What Do I Need To Take Apart To Do This. Thanks Darrell
Using the putty knife, push the clip on each side on top of the front panel and lift up the top panel.
Remove the wires from the door switch. Remove the screw on each side of the front panel, pull the top of the front panel toward yourself to release clips on the bottom. Lift the drum from the back to release it from the bearing and pull toward yourself. - The part number for the belt AP2142651 - Here are the break down diagrams for the Kelvinator dryer Model DEA500F2W Gene. |
| All times are GMT -7. The time now is 07:29 AM. |
