bkcprice1
#1 Posted : Wednesday, February 25, 2009 1:02:37 PM(UTC)
bkcprice1
Okay here's my problem(s)
First the timer stopped moving in the Auto Dry Cycle, it would just run forever. So I started using the timed Cycle instead.
Then it stopped drying. The heater would only turn on now and then and then only for a short while.
I replaced the Thermal cut off kit, which includes both thermostats.
This didn't help but I did notice that the igniter would turn on and off but the burner didn't light.
So I replaced the Flame Sensor and both Solenoid Coils.
IT WORKED...for one load!
Now the igniter doesn't even turn on. So now what do I do?
By the way I have checked and cleaned out the vent.
kayakcrzy
#2 Posted : Thursday, February 26, 2009 4:47:38 AM(UTC)
kayakcrzy
There is a thermal fuse in the back of the dryer. Take the back off, and you will see the thermal fuse. It is white in color, and is a 1/2 wide, and an inch and a half long. That would stop the ignitor from coming on. Tom ApplianceEducator.com
bkcprice1
#3 Posted : Thursday, February 26, 2009 7:23:06 AM(UTC)
bkcprice1
Tom,
Thanks, do you know if I can check it with a multimeter and how to see if its okay or is it a either it works or it doesn't type item? Bob
kayakcrzy
#4 Posted : Thursday, February 26, 2009 1:16:23 PM(UTC)
kayakcrzy
Yes Bob, take the 2 wires off of the thermal fuse, and of course the dryer is unplug when we do this, and then check the thermal fuse on ohms to see if you get a reading. If no reading it is bad. Tom ApplianceEducator.com
Maytag MDG8400AWW gas dryer not drying clothes (Dryer Repair)
by tvr4 12/31/2023 2:45:43 PM(UTC)
Whirlpool Gas Dryer Not Drying Clothes correctly (Dryer Repair)
by ts_peach 1/16/2011 10:40:07 AM(UTC)
Kenmore Elite HE3 Gas Dryer not drying (Dryer Repair)
by TKerscher 6/19/2009 5:43:30 PM(UTC)
Maytag gas dryer not drying (Dryer Repair)
by scott805 2/10/2009 9:19:33 PM(UTC)
Gas Dryer not drying during run cycles (Dryer Repair)
by GMP 9/26/2007 7:09:12 AM(UTC)
