Discuss
Whirlpool Duet Dryer (WED 9600TW0) Won't Turn
 in
Dryer Repair
I'm hoping someone can answer this question on my Whirlpool Duet Steam Dryer. Recently the dryer stopped turning. All electronics
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool Duet Dryer (WED 9600TW0) Won't Turn
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 06-10-2011, 05:58 AM
Junior Member
ZMonet is on a distinguished road
Default Whirlpool Duet Dryer (WED 9600TW0) Won't Turn
Model Number: WED9600TW0   Brand: Whirlpool   Age: 1 - 5 years
I'm hoping someone can answer this question on my Whirlpool Duet Steam Dryer. Recently the dryer stopped turning. All electronics come on, but when I go to run the dryer, after setting the program, the machine just gives a click and then the timer just runs down. The drum never turns and there is no heat. There are no error codes stored in the diagnostics. 220v are coming from the outlet. I removed the toe plate and attempted to check for continuity on the thermal fuse, but it seemed to be ok. Do you know what the click I'm hearing could mean? To be clear, I select a porgram, hold down start and usually the dryer immediately begins turning/heating. Right now there is a one second delay and then a click and then nothing. Is this usually the thermal fuse being bad or are there other things I should be looking at? Thanks for your help!
Related Models
Whirlpool WED9600TW0 27" ELECTRIC DRYER
Whirlpool WED9600TW1 27" ELECTRIC DRYER
Whirlpool WED9600TW2 27" ELECTRIC DRYER
Whirlpool WED9600TZ0 27" ELECTRIC DRYER
Whirlpool WED9610XW0 27" ELECTRIC DRYER
Whirlpool WED9750WL0 27" ELECTRIC DRYER
Whirlpool WED9750WR0 27" ELECTRIC DRYER
Whirlpool WED9750WW0 27" ELECTRIC DRYER
Whirlpool WED97HEXL0 ELECTRIC DRYER
Whirlpool WED97HEXL1 27" ELECTRIC DRYER
Whirlpool WED97HEXL2 27" ELECTRIC DRYER
Whirlpool WED97HEXR0 ELECTRIC DRYER
Whirlpool WED97HEXR1 27" ELECTRIC DRYER
Whirlpool WED97HEXR2 27" ELECTRIC DRYER
Whirlpool WED97HEXW0 ELECTRIC DRYER
Whirlpool WED97HEXW1 27" ELECTRIC DRYER
Whirlpool WED97HEXW2 27" ELECTRIC DRYER
White Westinghouse WEF303PHDA White Westinghouse/electric Range
White Westinghouse WEF303PHDB White Westinghouse/electric Range
White Westinghouse WEF303PHWA White Westinghouse/electric Range
White Westinghouse WEF303PHWB White Westinghouse/electric Range
White Westinghouse WEF311SHDA White Westinghouse/electric Range
White Westinghouse WEF311SHWA White Westinghouse/electric Range
Frigidaire WEF322BADA Wwh(v1) / Electric Range
Frigidaire WEF322BADB Wwh(v1) / Electric Range
Frigidaire WEF322BADC Wwh(v2) / Electric Range
Frigidaire WEF322BADD Wwh(v1) / Electric Range
Frigidaire WEF322BAWA Wwh(v2) / Electric Range
Frigidaire WEF322BAWB Wwh(v3) / Electric Range
Frigidaire WEF322BAWC Wwh(v4) / Electric Range
Frigidaire WEF322BAWD Wwh(v2) / Electric Range
Frigidaire WEF322BEDA Wwh(v1) / Electric Range
Frigidaire WEF322BEDB Wwh(v1) / Electric Range
Frigidaire WEF322BEWA Wwh(v2) / Electric Range
Frigidaire WEF322BEWB Wwh(v2) / Electric Range
Frigidaire WEF322BEWC Frg(v0) / Electric Range
Frigidaire WEF322SADA Wwh(v1) / Electric Range
Frigidaire WEF322SADB Wwh(v1) / Electric Range
Frigidaire WEF322SADC Wwh(v5) / Electric Range
Frigidaire WEF322SADD Wwh(v3) / Electric Range
Frigidaire WEF322SAWA Wwh(v2) / Electric Range
Frigidaire WEF322SAWB Wwh(v2) / Electric Range
Frigidaire WEF322SAWC Wwh(v6) / Electric Range
Frigidaire WEF322SAWD Wwh(v4) / Electric Range
White Westinghouse WEF326GSA ELECTRIC RANGE
White Westinghouse WEF326GSB ELECTRIC RANGE
Frigidaire WEF350BADB Wwh(v1) / Electric Range
Frigidaire WEF350BADC Wwh(v1) / Electric Range
Frigidaire WEF350BAWB Wwh(v2) / Electric Range
Frigidaire WEF350BAWC Wwh(v2) / Electric Range
Frigidaire WEF350CASA Wwh(v0) / Electric Range
White Westinghouse WEF350ESA White Westinghouse/range
White Westinghouse WEF350ESB White Westinghouse/range
Frigidaire WEF350SADA Wwh(v1) / Electric Range
Frigidaire WEF350SADB Wwh(v1) / Electric Range
Frigidaire WEF350SADC Wwh(v3) / Electric Range
Frigidaire WEF350SAWA Wwh(v2) / Electric Range
Frigidaire WEF350SAWB Wwh(v2) / Electric Range
Frigidaire WEF350SAWC Wwh(v4) / Electric Range
White Westinghouse WEF351ESA White Westinghouse/range
White Westinghouse WEF351ESB White Westinghouse/range
White Westinghouse WEF351ESC WHITE-WESTINGHOUSE/RANGE
Frigidaire WEF352BADA Wwh(v1) / Electric Range
Frigidaire WEF352BADB Wwh(v2) / Electric Range
Frigidaire WEF352BAWA Wwh(v3) / Electric Range
Frigidaire WEF352BAWB Wwh(v4) / Electric Range
Frigidaire WEF352BEDA Wwh(v1) / Electric Range
Frigidaire WEF352BEDB Wwh(v1) / Electric Range
Frigidaire WEF352BEDC Wwh(v1) / Electric Range
Frigidaire WEF352BEWA Wwh(v2) / Electric Range
Frigidaire WEF352BEWB Wwh(v2) / Electric Range
Frigidaire WEF352BEWC Wwh(v2) / Electric Range
Frigidaire WEF357BADA Wwh(v1) / Electric Range
Frigidaire WEF357BADB Wwh(v1) / Electric Range
Frigidaire WEF357BADC Wwh(v1) / Electric Range
Frigidaire WEF357BADD Wwh(v2) / Electric Range
Frigidaire WEF357BAWA Wwh(v2) / Electric Range
Frigidaire WEF357BAWB Wwh(v2) / Electric Range
Frigidaire WEF357BAWC Wwh(v3) / Electric Range
Frigidaire WEF357BAWD Wwh(v4) / Electric Range
White Westinghouse WEF360ESB White Westinghouse/range
White Westinghouse WEF360ESC White Westinghouse/range
White Westinghouse WEF360ESD White Westinghouse/range
White Westinghouse WEF361ESA White Westinghouse/range
White Westinghouse WEF361ESB White Westinghouse/range
White Westinghouse WEF361ESC White Westinghouse/range
White Westinghouse WEF361ESD White Westinghouse/range
White Westinghouse WEF365BHDA White Westinghouse/electric Range
White Westinghouse WEF365BHDB White Westinghouse/electric Range
White Westinghouse WEF365BHWA White Westinghouse/electric Range
White Westinghouse WEF365BHWB White Westinghouse/electric Range
White Westinghouse WEQ332HS0 ELECTRIC DRYER
White Westinghouse WER111ES0 White Westinghouse/dryer
White Westinghouse WER211CES0 White Westinghouse/dryer
White Westinghouse WER211ES0 White Westinghouse/dryer
Whirlpool WERC3100PQ0 30" ELECTRIC FREESTANDING SELF CLEAN CONVECTION OVEN
Whirlpool WERC3100PQ1 30" ELECTRIC FREESTANDING SELF CLEAN CONVECTION OVEN
Whirlpool WERC3100PQ2 30" ELECTRIC FREESTANDING SELF CLEAN CONVECTION OVEN
Whirlpool WERC4101SB0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN OVEN
Whirlpool WERC4101SB1 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN OVEN
Whirlpool WERC4101SB2 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN OVEN
Whirlpool WERC4101SB3 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN OVEN
Whirlpool WERC4101SQ0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN OVEN
Whirlpool WERC4101SQ1 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN OVEN
Whirlpool WERC4101SQ2 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN OVEN
Whirlpool WERC4101SQ3 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN OVEN
Whirlpool WERE3000PB4 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Whirlpool WERE3000PB5 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Whirlpool WERE3000PQ0 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Whirlpool WERE3000PQ1 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Whirlpool WERE3000PQ2 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Whirlpool WERE3000PQ4 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Whirlpool WERE3000PQ5 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Whirlpool WERE3000SB0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN OVEN
Whirlpool WERE3000SB1 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN OVEN
Whirlpool WERE3000SB2 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN OVEN
Whirlpool WERE3000SQ0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN OVEN
Whirlpool WERE3000SQ1 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN OVEN
Whirlpool WERE3000SQ2 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN OVEN
Whirlpool WERE3100PQ0 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Stupid Whirlpool Duet Wont Turn On sarawins Washer Repair 12 01-10-2016 10:48 AM
Whirlpool duet doesnt heat or turn timer working astarr Dryer Repair 3 11-04-2010 04:30 AM
Whirlpool Duet Washer won't turn on tommyhal Dishwasher Repair 9 08-04-2010 05:04 PM
Whirlpool Duet Washer won't turn on tommyhal Washer Repair 6 07-14-2010 04:33 AM
Whirlpool Duet Dryer clicks, but does not turn KPfromIowa Dryer Repair 6 06-27-2010 06:01 PM
