JEEP
#1 Posted : Tuesday, February 24, 2009 6:42:51 PM(UTC)
JEEP
had to replace heating element,both thermostats and thermial cut off. now dryer is running way to hot even at lowest setting.:eek:
#2 Posted : Wednesday, February 25, 2009 1:29:58 AM(UTC)
The cycling thermostat is marked usually 145 degrees and located on the blower housing. Make sure you didn't replace it with a 248 degree thermostat.
JEEP
#3 Posted : Wednesday, February 25, 2009 4:39:13 AM(UTC)
JEEP
thank you i will check that out tonight.
JEEP
#4 Posted : Thursday, February 26, 2009 4:37:22 AM(UTC)
JEEP
How To You Tell The Difference Between Thermostats Old And New Not Labeled
#5 Posted : Thursday, February 26, 2009 5:53:09 AM(UTC)
Put them in an oven and check with an ohmeter
1998 Maytag Gas Dryer Drum Issue Has Me Stumped (Dryer Repair)
by semaas 4/22/2024 9:44:18 PM(UTC)
Whirlpool gas dryer model WGD8300SW2 (Dryer Repair)
by Guest 4/20/2024 7:14:50 AM(UTC)
WED4815EW1 Dryer overheating? (Dryer Repair)
by Guest 4/16/2024 12:21:03 PM(UTC)
DLEX5780WE lg dryer shutting off before the clothes are dry. (Dryer Repair)
by LMA 4/13/2024 11:00:21 AM(UTC)
help maytag comercial dryer (Dryer Repair)
by blackwell316 4/4/2024 5:05:48 PM(UTC)
grease for rear dryer bearing (Dryer Repair)
by bronn033 3/30/2024 12:57:30 PM(UTC)
Kenmore Gas Dryer Running Hot (Dryer Repair)
by Guest 3/30/2024 6:24:53 AM(UTC)
Kenmore 100 dryer Heating Element (Dryer Repair)
by postalservice21 3/27/2024 6:43:17 AM(UTC)
Maytag electric dryer model MDE6400AYQ (Dryer Repair)
by Guest 3/25/2024 10:05:21 AM(UTC)
GE Dryer Timer and Housing (Dryer Repair)
by Guest 3/25/2024 7:47:59 AM(UTC)
Samsung dryer motor (Dryer Repair)
by Guest 3/24/2024 11:17:52 AM(UTC)
Replacement dryer motor W11364931 (Dryer Repair)
by Guest 3/23/2024 8:47:41 AM(UTC)
Maytag electirc dryer model LDE9334ACM (Dryer Repair)
by Guest 3/22/2024 6:07:19 PM(UTC)
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
Electric Dryer Amana NED7300WW1 (Dryer Repair)
by AlexanderK 3/13/2024 1:37:06 PM(UTC)
