AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Whirpool Duet Gas Dryer control panel problems
My Whirpool Duet Gas Dryer 9200lw1 is acting a little funny. A month ago, was the first time it happened. Dryer completed drying a load. I put another load in, pushed Start, LEDs on, selected cycle and tried to adjust drying level and time but nothing registered. Pushed Pause/Cancel and nothing happened, when I spun the function dial, it would change cycles but you could not adjust anything else. Also, machine would not start. I tried unplugging and plugging back in. That didn't work. So i gave up and came back in 2 hours. Machine worked fine. It's been working fine for a month, but the same problem came back today.
I called Whirpool. They said it sounds like a control panel problem. Machine is out of warrranty, so they recommended a repair tech. If the problem is a faulty control panel, can I repair it myself?
Thank you, Maurice
Dryer Repair
