inside spins but no heat. replaced double fuse (I dropped on floor could it have broken inside?) and it still doesn's heat. what else could it be?:confused:
so what do I need to do, can this be fixed easily or do I need to call a repair man
Here are your parts Replacement parts for FRIGIDAIRE GLER331AS2 Frigidaire/dryer | AppliancePartsPros.comHere is the tech sheet http://manuals.frigidaire.com/prodinfo_pdf/Webster/134054800.pdfSorry but I do not know what you are calling a "double fuse" First thing to check is the power. Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker. The motor and timer run off of 120 volts but the heating coil requires the full 240. If this does nothing, check the voltage at the plug L1 to L2 should be 240 volts L1 to Neutral and L2 to Neutral, both should be 120 volts. If OK Unplug the unit and check the wires at the terminal strip in the machine to make sure none are loose or burned out If OK Check the power at the terminal strip. Do this with the heater off and on. [COLOR="Red"] Be careful as 240 volts is lethal !!![/COLOR] |
THIS FORUM IS DEAD!!!!!!! |
