Discuss
Whirlpool dryer will not run
 in
Dryer Repair
Ok I have a bit of smarts but this has got me stumped. I have a whirlpool dryer that was
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool dryer will not run
  #1 (permalink)
Old 02-24-2009, 11:25 AM
Junior Member
lormak2598 is on a distinguished road
Exclamation Whirlpool dryer will not run
Model Number: LER4634JQ1   Brand: Whirlpool   Age: 1 - 5 years
Ok I have a bit of smarts but this has got me stumped. I have a whirlpool dryer that was given to me for free. When the other person had it the unit was working. I had to change the power cable since my outlet would not acept the cord and all went well. I have 242V across the outside terms. I check the resistance on the thermal fuse (.02) so that is ok.
The thing that bothers me is the timer will not even run when plugged in. What about checking the door switch? What terminals do I probe to check continuity?
Help and any other suggestions.
Update: I did check the door switch and it is ok, but I found something interesting with the voltage lines on back.
Red to Black = 242V
Black to Neutral 59.5V
Red to Neutral= 182V
Just on a whim I flipped the wires the only one that changed was Black to Neutral = 51.7V
Hope this helps.
Ads By Google
Related Models
Whirlpool LER4634JQ1
Whirlpool LER4634JQ2 29" Electric Dryer
Whirlpool LER4634JT0
Whirlpool LER4634JT1
Whirlpool LER4634JT2 29" Electric Dryer
Whirlpool LER4634JZ0
Whirlpool LER4634PQ0 29" Electric Dryer
Whirlpool LER4634PQ1 29" Electric Dryer
Whirlpool LER4634PT0 29" Electric Dryer
Whirlpool LER4634PT1 29" Electric Dryer
Whirlpool LER5434AN0
Whirlpool LER5434AW0
Whirlpool LER5600HQ0
Whirlpool LER5600HZ0
Whirlpool LER5600JQ0
Whirlpool LER5600JT0
Whirlpool LER5620KQ0
Whirlpool LER5620KQ1
Whirlpool LER5620KQ2 29"electric Dryer
Whirlpool LER5624BN0
Whirlpool LER5624BN1
Whirlpool LER5624BN2
Whirlpool LER5624BW0
Whirlpool LER5624BW1
Whirlpool LER5624BW2
Whirlpool LER5624DQ0
Whirlpool LER5624DQ1
Whirlpool LER5624DW1
Whirlpool LER5624DZ0
Whirlpool LER5624DZ1
Whirlpool LER5634AN0
Whirlpool LER5634AQ0
Whirlpool LER5634AQ1
Whirlpool LER5634AQ2
Whirlpool LER5634AW0
Whirlpool LER5634DQ1
Whirlpool LER5634EQ0
Whirlpool LER5634EZ0
Whirlpool LER5634LG0
Whirlpool LER5634LQ0 29" Electric Dryer
Whirlpool LER5634LT0
Whirlpool LER5634LW0
Whirlpool LER5635LQ0 29"electric Dryer
Whirlpool LER5635LQ1 29"electric Dryer
Whirlpool LER5636DW0
Whirlpool LER5636DW1
Whirlpool LER5636EQ0
Whirlpool LER5636EQ1
Whirlpool LER5636EQ2
Whirlpool LER5636EQ3
Whirlpool LER5636EZ0
Whirlpool LER5636EZ1
Whirlpool LER5636EZ2
Whirlpool LER5636EZ3
Whirlpool LER5636JQ0
Whirlpool LER5636JT0
Whirlpool LER5636KQ0
Whirlpool LER5636KQ1
Whirlpool LER5636KT0
Whirlpool LER5636KT1
Whirlpool LER5636LG0
Whirlpool LER5636LQ0
Whirlpool LER5636LQ1 29"electric Dryer
Whirlpool LER5636LT0
Whirlpool LER5636LT1 29"electric Dryer
Whirlpool LER5636LW0
Whirlpool LER5636PQ0 29"electric Dryer
Whirlpool LER5636PQ1 29"electric Dryer
Whirlpool LER5636PT0 29"electric Dryer
Whirlpool LER5636PT1 29"electric Dryer
Whirlpool LER5638AN0
Whirlpool LER5638AN1
Whirlpool LER5638AN2
Whirlpool LER5638AN3
Whirlpool LER5638AW0
Whirlpool LER5638AW1
Whirlpool LER5638AW2
Whirlpool LER5638AW3
Whirlpool LER5644AN0
Whirlpool LER5644AN1
Whirlpool LER5644AN2
Whirlpool LER5644AW0
Whirlpool LER5644AW1
Whirlpool LER5644AW2
Whirlpool LER5644EQ0
Whirlpool LER5644EQ1
Whirlpool LER5644EQ2
Whirlpool LER5644EZ0
Whirlpool LER5644EZ1
Whirlpool LER5644EZ2
Whirlpool LER5644JQ0
Whirlpool LER5644JQ1
Whirlpool LER5644JQ2
Whirlpool LER5644JQ3 29"electric Dryer
Whirlpool LER5644JT0
Whirlpool LER5644JT1
Whirlpool LER5644JT2
Whirlpool LER5644JT3 29"electric Dryer
Whirlpool LER5644PQ0 29"electric Dryer
Whirlpool LER5644PQ1 29"electric Dryer
Whirlpool LER5700KQ0
Whirlpool LER5700KQ1
Whirlpool LER5700KT0
Whirlpool LER5700KT1
Whirlpool LER5848EQ0
Whirlpool LER5848EQ1
Whirlpool LER5848EQ2
Whirlpool LER5848EQ3
Whirlpool LER5848EQ4
Whirlpool LER5848EQ5
Whirlpool LER6611LQ0
Whirlpool LER6611LQ1 29"electric Dryer
Whirlpool LER6611PQ0 29" Electric Dryer
Whirlpool LER6620PQ0 29"electric Dryer
Whirlpool LER6620PQ1 29"electric Dryer
Whirlpool LER6620PT0 29"electric Dryer
Whirlpool LER6620PT1 29"electric Dryer
Whirlpool LER6621PQ0 29" Electric Dryer
Whirlpool LER6634BN0
Whirlpool LER6634BN1
  #2 (permalink)
Old 02-24-2009, 01:49 PM
Senior Expert
APP Volunteer
denman is just really nice
Default
When you say you changed the power cable was it from a 4 prong to a 3 prong?
If yes you have to connect a grounding strap from Neutral to the machine frame.
Unplug the dryer and measure the line voltage.
If it is still no good you have a house wiring problem.
You may have a bad Neutral.
__________________
  #3 (permalink)
Old 02-24-2009, 03:17 PM
Junior Member
Default
No the original cable was three wire but different design connectors. I check line voltage at hose connection and have 240V across the main terms.
I took drum out and have the motor exposed but the thing that concerns me is that there is only 59.V going down from term block to motor. I will say this that sometines when I touch certain parts of the dryer I get a low level shock, to me this is not normal.
  #4 (permalink)
Old 02-24-2009, 03:36 PM
Senior Expert
APP Volunteer
Drags1998 is on a distinguished road
Default
WOH, Back up the BUS, Unplug the dryer, Go to the WALL Rec, R-B=240,R-W=120,B-W=120, If you have ANYTHING other than this, The problem is NOT in the dryer, Its in the HOUSE WIRING!!!!
__________________
  #5 (permalink)
Old 02-24-2009, 03:55 PM
Junior Member
Thumbs up
Well with the advice I checked something, I live in my x father in law apartment building and he has another set of Washer and dryer.
I probed the known good connector and did get the correct values as stated earlier. I went back to bad rec and found 240/30/30. I opend up adjacent elect box and foung the neutral is not connected to anything. I will attch and retest and post results.
  #6 (permalink)
Old 02-24-2009, 06:27 PM
Junior Member
Thumbs up
Ok all is well now, dryer works flawlesly, thank you for the ideas and advise.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Burned Dryer Plug - Whirlpool Electric Dryer EastCobbSnob Dryer Repair 4 11-17-2009 06:45 PM
whirlpool Dryer Tammy43 Dryer Repair 1 11-04-2009 04:33 PM
Whirlpool Gas Dryer SandraB Dryer Repair 3 07-24-2009 01:49 PM
Whirlpool Dryer Has no Heat in Dryer jsanabia Dryer Repair 1 06-08-2009 04:36 PM
Estate Dryer by Whirlpool/Dryer running but no heat tsm11238 Dryer Repair 1 11-06-2007 10:47 AM
