Great site. I used the instructions I found here and determined that I need to replace my Dryer Cycling Thermostat Do you have any instructions how to replace the part?
Originally Posted by: bamcconnell Great site. I used the instructions I found here and determined that I need to replace my Dryer Cycling Thermostat Do you have any instructions how to replace the part? BAM, Your cycling/regulating thermostat, Part number: AP3131939
is located on the back side of the blower and drum inlet flue. You'll need to remove the rear panel of the dryer cabinet to access it. Make sure you unplug the power cord, and you may want to shut off the gas supply, as well. Be carefull with the back panel and cabinet, lots of screws and sharp edges. :cool: :cool: :cool:
