Discuss
Dryer Smells Like Partially Burnt Fuel
 in
Dryer Repair
My gas dryer recently started to smell like partially brunt fuel. I can smell it a litte inside and stronger
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer Smells Like Partially Burnt Fuel
  #1 (permalink)
Old 02-23-2009, 05:45 PM
Junior Member
jmnardo is on a distinguished road
Default Dryer Smells Like Partially Burnt Fuel
Brand: Kenmore   Age: More than 10 years
My gas dryer recently started to smell like partially brunt fuel. I can smell it a litte inside and stronger outside. I can sometimes smell it on our clothes, but not usually. It was a natural gas dryer when new, but it was converted to propane about 15 years ago.
I checked the vent and it appeared clear. I did clean it out and shorten the flex hose. That seemed to help, but the smell came back.
I read a post here that a kerosene smell can be due to painting fumes. To me it smells more like incomplete combustion, but I could see it described as smelling like kerosene. I did start noticing this smell after I started refinishing the cabinets in the house. I've been spraying a catalized varnish and brushing a polyurathane. Could this really be the source? I would not think there were enough volitized hydrocarbons to make a smell like that in the close dryer. I suppose the real test will be seeing if the smell remains when I'm done refinishing. I just want to make sure there is not a more serious problem.
Any thoughts?
Thanks, Mike
  #2 (permalink)
Old 02-24-2009, 07:19 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Mike,
You have to take the dryer apart and thoroughly clean it. Very likely there is a burned lint inside.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 02-24-2009, 07:43 PM
Junior Member
moeman12 is on a distinguished road
Default
Mike,
I'm not a repair tech, but last year I refinished by bathroom cabinets with stain. Later in the day, I started the gas dryer and smelled the same kerosene smell. I thought I had a gas leak. Called the gas company. When they arrived, they instantly knew what the problem was. The stain fumes were being burned in the dryer, hence the smell. I was told to wait a day or two till the staining smell depleted before using the dryer again. I rewashed the load of clothes to get the kerosene smell out, used the dryer and all is well.
Hope this helps.
-Moe
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
won't agitate but will spin smells burnt makes noise washeral Washer Repair 1 08-23-2009 06:37 AM
dryer smells rmk Dryer Repair 1 06-23-2009 02:49 AM
Dryer sometimes doesn't dry and smells burnt wasabismom Dryer Repair 2 03-13-2009 10:41 AM
kenmore mic hums and smells burnt miran587 Microwave Repair 0 01-14-2009 06:48 PM
dryer smells ginny Dryer Repair 2 10-20-2007 02:42 AM
