| » Thermal Fuse |
Model Number: LER4634EZ0 Brand: Whirlpool Age: 5 - 10 years
ELECT DRYER ......HEATING ELEMENT WILL NOT GO ON UNLESS i BYPASS AND TAPE TOGETHER THE 2 RED WIRES REMOVED FROM A FUSE??? # 3399848........THEN THE ELEMENT HEATS UP.............
THIS IS AN ELECTRIC DRYER Ads By Google Related Models Last edited by peter baker : 06-07-2011 at 04:11 PM. |
Quote:
IS THIS A FUSE AND IS IT DEFECTIVE |
Here are your parts.
Yes it is a fuse though they call it a thermal cutoff AP3094244 (Item 6 in Section 3) I doubt it is defective, they usually blow for a reason. Check the heating coil. Unplug the unit and both wires to the coil. Check it with a meter, should be around 10 to 12 ohms. Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it so the thermal cut-off blows. The hi-limit should have regulated the temperature so the fuse did not blow, that is why there is a new one with the thermal cut-off.. Note: That unless there is another problem in the unit the hi-limit should never have to open. It is just a safety device with the fuse being a backup safety device. Just in case it is not a grounded element. With all the below the high limit will also have to be replaced. Check that the belt is OK. Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot. Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow. Check/clean your vent system. Check/clean the blower wheel. If all OK you may want to replace the cycling thermostat as it's contacts may not be opening (welded shut)
__________________
| Display Modes | |
| What is fuse thermal for? | D&JAnderson | Dryer Repair | 0 | 02-23-2011 09:35 AM |
| Where is thermal fuse? | mnumbers | Dryer Repair | 1 | 12-15-2010 01:38 AM |
| Thermal Fuse | rdraw52 | Dryer Repair | 2 | 03-06-2010 02:04 AM |
| Where is Thermal Fuse Please | dpotts | Dryer Repair | 3 | 05-17-2009 05:09 PM |
| Thermal Fuse | jcolenda | Dishwasher Repair | 2 | 10-02-2008 07:55 AM |
