Hello, My dryer spot working, so I checked the thermal fuses, door switch, and belt safety switch, start switch and all check OK. I replaced the motor with a new one from AppliancePartsPros, but the wiring directions that can with the motor we un-readable. The motor looked identical to the old one so I hooked it up the same way. still not running.
Can anyone help? Does anyone know if the wiring should be modified for this motor?
