i'm new to online forum stuff so forgive me if this has been brought up before. i have a whirlpool gold electric dryer that stopped heating and drying. Everything else seems to work o.k. I noticed this after i switched from a high heat dryer setting to a setting using no heat and just tumbling. After that was done we switched back to the regular heat setting and no heat. We tried moving the heat setting switch back and forth with no succes. dryer vent tube and vent are clear. Any suggestions on what it can be? I need to repair asap (3 kids, and usually 3 loads a day) and reapir company needs 2-weeks and is incredibly expensive. Thank you.
