Discuss
Flame sensor
 in
Dryer Repair
i was checking to see if the ignightor was working and lighting the dryer. the ignightor turned on and did
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Flame sensor
  #1 (permalink)
Old 02-21-2009, 10:18 AM
Junior Member
redrwut is on a distinguished road
Default Flame sensor
Model Number: dg482   Brand: Maytag   Age: More than 10 years
i was checking to see if the ignightor was working and lighting the dryer. the ignightor turned on and did light but took about 15-20 seconds to do. I turned the dryer off and reatarted it. as i was waiting, i tapped the side of the burner tube and it caused the gas to open and light. would that indicate a bad flame sensor or could it be just a loose connection? i cleaned off the sensor glass also. what are the symtoms of a bad flame sensor?
thank you
Louie
Ads By Google
Related Models
Maytag DG482 Dryer - Gas
Maytag DG482D Dryer - Gas
Maytag DG490 Dryer - Gas
Maytag DG490D Dryer - Gas
Maytag DG4910 Dryer - Gas
Maytag DG500 Dryer - Gas
Frigidaire DG500AXD5 Wwh(v4) / 27 " Gas Dryer
Frigidaire DG500AXD6 Wwh(v4) / 27 " Gas Dryer
Frigidaire DG500AXW5 Wwh(v3) / 27 " Gas Dryer
Frigidaire DG500AXW6 Wwh(v3) / 27 " Gas Dryer
Frigidaire DG500EXD1 Wwh(v16) / Gas Dryer
Frigidaire DG500EXD4 Wwh(v17) / Gas Dryer
Frigidaire DG500EXD5 Wwh(v18) / Gas Dryer
Frigidaire DG500EXF1 Wwh(v19) / Gas Dryer
Frigidaire DG500EXF4 Wwh(v20) / Gas Dryer
Frigidaire DG500EXF5 Wwh(v21) / Gas Dryer
Frigidaire DG500EXH1 Wwh(v22) / Gas Dryer
Frigidaire DG500EXH4 Wwh(v23) / Gas Dryer
Frigidaire DG500EXH5 Wwh(v24) / Gas Dryer
Frigidaire DG500EXV1 Wwh(v25) / Gas Dryer
Frigidaire DG500EXV4 Wwh(v26) / Gas Dryer
Frigidaire DG500EXV5 Wwh(v27) / Gas Dryer
Frigidaire DG500EXW1 Wwh(v28) / Gas Dryer
Frigidaire DG500EXW4 Wwh(v29) / Gas Dryer
Frigidaire DG500EXW5 Wwh(v30) / Gas Dryer
Frigidaire DG500JXD1 Wwh(v6) / Gas Dryer
Frigidaire DG500JXF1 Wwh(v7) / Gas Dryer
Frigidaire DG500JXH1 Wwh(v8) / Gas Dryer
Frigidaire DG500JXV1 Wwh(v9) / Gas Dryer
Frigidaire DG500JXW1 Wwh(v10) / Gas Dryer
Frigidaire DG500KXD1 Wwh(v6) / Gas Dryer
Frigidaire DG500KXD2 Wwh(v6) / 27 " Gas Dryer
Frigidaire DG500KXD3 Wwh(v3) / 27 " Gas Dryer
Frigidaire DG500KXD4 Wwh(v3) / 27 " Gas Dryer
Frigidaire DG500KXD5 Wwh(v3) / 27 " Gas Dryer
Frigidaire DG500KXD6 Wwh(v2) / 27 " Gas Dryer
Frigidaire DG500KXH1 Wwh(v5) / Gas Dryer
Frigidaire DG500KXH2 Wwh(v5) / 27 " Gas Dryer
Frigidaire DG500KXH3 Wwh(v2) / 27 " Gas Dryer
Frigidaire DG500KXH4 Wwh(v2) / 27 " Gas Dryer
Frigidaire DG500KXH5 Wwh(v2) / 27 " Gas Dryer
Frigidaire DG500KXW1 Wwh(v4) / Gas Dryer
Frigidaire DG500KXW2 Wwh(v4) / 27 " Gas Dryer
Frigidaire DG500KXW3 Wwh(v1) / 27 " Gas Dryer
Frigidaire DG500KXW4 Wwh(v1) / 27 " Gas Dryer
Frigidaire DG500KXW5 Wwh(v1) / 27 " Gas Dryer
Frigidaire DG500KXW6 Wwh(v1) / 27 " Gas Dryer
Maytag DG510 Dryer - Gas
Maytag DG512 Dryer - Gas
Maytag DG512D Dryer - Gas
Frigidaire DG5520RW1 Frg(v1) / 27 " Gas Dryer
Frigidaire DG5520RW2 Frg(v1) / 27 " Gas Dryer
Frigidaire DG5800ADD1 Frg(v4) / 27 " Gas Dryer
Frigidaire DG5800AWW1 Frg(v3) / 27 " Gas Dryer
Frigidaire DG5800RW1 Frg(v1) / 27 " Gas Dryer
Frigidaire DG5800RW2 Frg(v1) / 27 " Gas Dryer
Maytag DG590 Dryer - Gas
Maytag DG590D Dryer - Gas
Maytag DG5910 Dryer - Gas
Frigidaire DG600AXD1 Wwh(v4) / 27 " Gas Dryer
Frigidaire DG600AXD2 Wwh(v2) / 27 " Gas Dryer
Frigidaire DG600AXW1 Wwh(v3) / 27 " Gas Dryer
Frigidaire DG600AXW2 Wwh(v3) / 27 " Gas Dryer
Frigidaire DG600EXD1 Wwh(v1) / Gas Dryer
Frigidaire DG600EXD2 Wwh(v2) / Gas Dryer
Frigidaire DG600EXD4 Wwh(v3) / Gas Dryer
Frigidaire DG600EXD5 Wwh(v4) / Gas Dryer
Frigidaire DG600EXF1 Wwh(v5) / Gas Dryer
Frigidaire DG600EXF2 Wwh(v6) / Gas Dryer
Frigidaire DG600EXF4 Wwh(v7) / Gas Dryer
Frigidaire DG600EXF5 Wwh(v8) / Gas Dryer
Frigidaire DG600EXH1 Wwh(v9) / Gas Dryer
Frigidaire DG600EXH2 Wwh(v10) / Gas Dryer
Frigidaire DG600EXH4 Wwh(v11) / Gas Dryer
Frigidaire DG600EXH5 Wwh(v12) / Gas Dryer
Frigidaire DG600EXV1 Wwh(v13) / Gas Dryer
Frigidaire DG600EXV2 Wwh(v14) / Gas Dryer
Frigidaire DG600EXV4 Wwh(v15) / Gas Dryer
Frigidaire DG600EXV5 Wwh(v16) / Gas Dryer
Frigidaire DG600EXW1 Wwh(v17) / Gas Dryer
Frigidaire DG600EXW2 Wwh(v18) / Gas Dryer
Frigidaire DG600EXW4 Wwh(v19) / Gas Dryer
Frigidaire DG600EXW5 Wwh(v20) / Gas Dryer
Frigidaire DG600JXD1 Wwh(v1) / Gas Dryer
Frigidaire DG600JXF1 Wwh(v2) / Gas Dryer
Frigidaire DG600JXH1 Wwh(v3) / Gas Dryer
Frigidaire DG600JXV1 Wwh(v4) / Gas Dryer
Frigidaire DG600JXW1 Wwh(v5) / Gas Dryer
Frigidaire DG600KXD1 Wwh(v3) / Gas Dryer
Frigidaire DG600KXD2 Wwh(v3) / 27 " Gas Dryer
Frigidaire DG600KXD3 Wwh(v3) / 27 " Gas Dryer
Frigidaire DG600KXD4 Wwh(v3) / 27 " Gas Dryer
Frigidaire DG600KXD5 Wwh(v3) / 27 " Gas Dryer
Frigidaire DG600KXH2 Wwh(v2) / 27 " Gas Dryer
Frigidaire DG600KXH3 Wwh(v2) / 27 " Gas Dryer
Frigidaire DG600KXH4 Wwh(v2) / 27 " Gas Dryer
Frigidaire DG600KXH5 Wwh(v2) / 27 " Gas Dryer
Frigidaire DG600KXW1 Wwh(v1) / Gas Dryer
Frigidaire DG600KXW2 Wwh(v1) / 27 " Gas Dryer
Frigidaire DG600KXW3 Wwh(v1) / 27 " Gas Dryer
Frigidaire DG600KXW4 Wwh(v1) / 27 " Gas Dryer
Frigidaire DG600KXW5 Wwh(v1) / 27 " Gas Dryer
Maytag DG606 Dryer - Gas
Amana DG6060 Washer - Top Loading
Amana DG6061 Washer - Top Loading
Maytag DG608 Dryer - Gas
Amana DG6090 Washer - Top Loading
Amana DG6091 Washer - Top Loading
Maytag DG610 Dryer - Gas
Maytag DG612 Dryer - Gas
Maytag DG612D Dryer - Gas
Amana DG6161 Washer - Top Loading
Amana DG6181 Washer - Top Loading
Frigidaire DG620EXD1 Wwh(v7) / Gas and Electric Dryers
Frigidaire DG620EXD2 Wwh(v8) / Gas and Electric Dryers
Frigidaire DG620EXW1 Wwh(v9) / Gas and Electric Dryers
Frigidaire DG620EXW2 Wwh(v10) / Gas and Electric Dryers
Amana DG6240 Washer - Top Loading
Amana DG6241 Washer - Top Loading
Amana DG6270 Washer - Top Loading
  #2 (permalink)
Old 02-21-2009, 10:40 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
If the igniter will not allways turn the gas valve on, you probably have a bad igniter. If you have an amprobe, current should be well over 3 amps.The current may be near the trip point and tapping opened it up. Just order it from this site AP4037378
__________________
  #3 (permalink)
Old 02-21-2009, 10:44 AM
Junior Member
Default
the ignitor lights up brightly every time.
  #4 (permalink)
Old 02-21-2009, 10:49 AM
Junior Member
Default
i may have explained incorrectly. i tapped the large tube that the flame sensor is attached to. not the burner tube.
  #5 (permalink)
Old 02-21-2009, 03:21 PM
Senior Expert
APP Volunteer
Default
Repost this as either a failed heat or an intermittant one. If the igniter fails to open the gas valve it usually is a bad igniter.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
flame sensor Bob P Dryer Repair 0 01-19-2010 03:59 PM
Gas dryer Flame sensor gpulfer15 Dryer Repair 0 11-17-2009 07:23 AM
flame sensor lnarvaez Oven Repair (including Ranges and Cooktops) 0 09-12-2009 12:15 PM
flame sensor sarrah76 Dryer Repair 1 01-10-2009 05:38 AM
flame sensor sarrah76 Dryer Repair 1 01-10-2009 05:37 AM
