Discuss
Gas Dryer not heating---am I doing this right?
 in
Dryer Repair
OK I think I am doing this right but I am not an electrician or an appliance guy. I went
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Gas Dryer not heating---am I doing this right?
  #1 (permalink)
Old 02-19-2009, 04:57 PM
Junior Member
sparksaz is on a distinguished road
Default Gas Dryer not heating---am I doing this right?
Model Number: LGR7646EQ0   Brand: Whirlpool   Age: More than 10 years
OK I think I am doing this right but I am not an electrician or an appliance guy. I went through other posts on here and got out my Ohm meter and here are my numbers with wires unplugged when measuring.
Coil with two terminals: 1201 Ohms
Coil with three terminals: Left and Middle prongs are 1351 Ohms, Outer prongs are 561 Ohms, right and middle prongs are 1910 Ohms.
Thermal Fuse: Open on meter
Cycling Thermostat: Beeps
Ignitor: 780 Ohms
Flame Sensor: Beeps
Now I understand that the Thermal fuse should not be open so I believe this is the culprit. After reading "Gene's" information he gave on other topics I think I am on the right track but before I order up parts my questions are:
1) Am I reading this all right and
2) Would it be necessary to replace say the ignitor just for grins since the unit is over 10 years old.
I guess ultimately I don't know if my Ohm numbers are "good" numbers or understand how this thermal fuse thingy can make the whole heating assembly not work. I just want some assurance I am on the right track from someone out there that knows.
Ads By Google
Related Models
Whirlpool LGR7646EQ0
Whirlpool LGR7646EQ1
Whirlpool LGR7646EQ2
Whirlpool LGR7646EQ3
Whirlpool LGR7646EZ0
Whirlpool LGR7646EZ1
Whirlpool LGR7646EZ2
Whirlpool LGR7646EZ3
Whirlpool LGR7646JQ0
Whirlpool LGR7646JQ1
Whirlpool LGR7646JT0
Whirlpool LGR7646JT1
Whirlpool LGR7648KQ0
Whirlpool LGR7648KQ1
Whirlpool LGR7648KQ2 29"gas Dryer
Whirlpool LGR7648KT0
Whirlpool LGR7648KT1
Whirlpool LGR7648KT2 29"gas Dryer
Whirlpool LGR7648PQ0 29" Gas Dryer
Whirlpool LGR7648PQ1 29" Gas Dryer
Whirlpool LGR7648PT0 29" Gas Dryer
Whirlpool LGR7648PT1 29" Gas Dryer
Whirlpool LGR7848DQ0
Whirlpool LGR7848DQ1
Whirlpool LGR7848DZ0
Whirlpool LGR7848DZ1
Whirlpool LGR7858AN0
Whirlpool LGR7858AN1
Whirlpool LGR7858AN2
Whirlpool LGR7858AW0
Whirlpool LGR7858AW1
Whirlpool LGR7858AW2
Whirlpool LGR8620PG0 29"gas Dryer
Whirlpool LGR8620PG1 29"gas Dryer
Whirlpool LGR8620PW0 29"gas Dryer
Whirlpool LGR8620PW1 29"gas Dryer
Whirlpool LGR8646LG0
Whirlpool LGR8648LG1 29"gas Dryer
Whirlpool LGR8648LQ0
Whirlpool LGR8648LW0
Whirlpool LGR8648LW1 29"gas Dryer
Whirlpool LGR8648PG0 29"gas Dryer
Whirlpool LGR8648PG1 29" Gas Dryer
Whirlpool LGR8648PQ0 29" Gas Dryer
Whirlpool LGR8648PQ1 29" Gas Dryer
Whirlpool LGR8648PW0 29"gas Dryer
Whirlpool LGR8648PW1 29" Gas Dryer
Whirlpool LGR8857EQ0
Whirlpool LGR8857EQ1
Whirlpool LGR8857EQ2
Whirlpool LGR8857EQ3
Whirlpool LGR8857EZ0
Whirlpool LGR8857EZ1
Whirlpool LGR8857EZ2
Whirlpool LGR8857EZ3
Whirlpool LGR8858DQ0
Whirlpool LGR8858DQ1
Whirlpool LGR8858DZ0
Whirlpool LGR8858DZ1
Whirlpool LGR8858EQ0
Whirlpool LGR8858EQ1
Whirlpool LGR8858EQ2
Whirlpool LGR8858EQ3
Whirlpool LGR8858EZ0
Whirlpool LGR8858EZ1
Whirlpool LGR8858EZ2
Whirlpool LGR8858EZ3
Amana LGS10AW Washer - Top Loading
Amana LGS19AW Dryer - Gas
Amana LGS33AW Dryer - Gas
Amana LGS34AW Washer - Top Loading
Frigidaire LGS389FEA Frigidaire/gas Range
Whirlpool LGT5434AN0
Whirlpool LGT5434AQ0
Whirlpool LGT5434AW0
Whirlpool LGT5436AN0
Whirlpool LGT5436AW0
Whirlpool LGT5624BN0
Whirlpool LGT5624BN1
Whirlpool LGT5624BN2
Whirlpool LGT5624BQ0
Whirlpool LGT5624BQ1
Whirlpool LGT5624BQ2
Whirlpool LGT5624BW0
Whirlpool LGT5624BW1
Whirlpool LGT5624BW2
Whirlpool LGT5624DQ0
Whirlpool LGT5624DQ1
Whirlpool LGT6634AN0
Whirlpool LGT6634AN1
Whirlpool LGT6634AN2
Whirlpool LGT6634AQ0
Whirlpool LGT6634AQ1
Whirlpool LGT6634AQ2
Whirlpool LGT6634AW0
Whirlpool LGT6634AW1
Whirlpool LGT6634AW2
Whirlpool LGT6634DQ0
Whirlpool LGT6634DQ1
Whirlpool LGT6634DZ0
Whirlpool LGT6634DZ1
Whirlpool LGT6638AN0
Whirlpool LGT6638AN1
Whirlpool LGT6638AN2
Whirlpool LGT6638AQ0
Whirlpool LGT6638AQ2
Whirlpool LGT6638AW0
Whirlpool LGT6638AW1
Whirlpool LGT6638AW2
Whirlpool LGT6638DQ0
Whirlpool LGT6638DQ1
Whirlpool LGT6638DZ0
Whirlpool LGT6638DZ1
Whirlpool LGT7646AN0
Whirlpool LGT7646AQ0
Whirlpool LGT7646AQ2
Whirlpool LGT7646AW0
Whirlpool LGT7646AZ0
Whirlpool LGT7646AZ2
Whirlpool LGT7646DQ0
  #2 (permalink)
Old 02-19-2009, 05:42 PM
TechnicianBrian's Avatar
Senior Expert
APP Volunteer
TechnicianBrian is on a distinguished road
Default
You did good work and if those readings are accurate, then the thermal fuse is the problem and needs to be replaced. The fuse is a safety device that opens the heater circuit in the event of an over temp condition. So besides replacing the fuse, check your vent to the outside for anything that would restrict airflow, and ensure the connection at the back of the dryer is not folded over or kinked in any way. As for replacing parts for grins, it's up to you, but if it's been working well, I think I would wait. You already know how to take it apart and where to get the parts. Hope this helps.
__________________
TechnicianBrian
TechnicianBrian.com
AllTechAppliance.com
  #3 (permalink)
Old 02-20-2009, 06:19 PM
Junior Member
Default
Thanks for the reply. I realized after I posted it that it was a VERY common topic. I apologize for the redundancy.
I went out today and bought a new part, dryer works great. All it took was a couple hours to diagnose and $6 and back in business. I wonder how many people go out and buy new dryers when all it takes is a bit of time and money to find the problem. The internet is a great tool, sorry dryer repair man.
  #4 (permalink)
Old 02-20-2009, 06:44 PM
Senior Expert
APP Volunteer
Default
Glad I could help. These are the kinds of repairs that are perfect for the DIY'er.
__________________
TechnicianBrian
TechnicianBrian.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer not heating rcabalo Dryer Repair 2 11-26-2009 09:52 AM
dryer not heating iyacko Dryer Repair 2 08-26-2009 12:50 PM
dryer not heating ecubulldog Dryer Repair 1 07-05-2009 07:40 AM
Dryer not Heating stompy27 Dryer Repair 0 11-05-2008 06:06 AM
Gas dryer not heating Penthor Dryer Repair 3 02-17-2008 08:56 AM
