Discuss
Whirlpool Dryer Overheating
 in
Dryer Repair
I own a Whirlpool Duet Dryer Model: WED9200SQ- purchased Nov 2007. Two weeks ago it stopped working. *** 3 months
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool Dryer Overheating
  #1 (permalink)
Old 02-19-2009, 01:41 PM
Junior Member
jandelhart is on a distinguished road
Default Whirlpool Dryer Overheating
Model Number: WED9200SQ0   Brand: Whirlpool   Age: 1 - 5 years
I own a Whirlpool Duet Dryer Model: WED9200SQ- purchased Nov 2007. Two weeks ago it stopped working. *** 3 months after One Year Warranty*** Power on, buttons work, timer starts counting down, but no tumbling, no air, no heat. I am no expert repairman but thought with a little research I might be able to figure this out myself. I found some info online that suggested I check the continuity of the Thermal Fuse and to be sure the vent is clear. Sure enough, vent was partially clogged (which obviously caused increased Heat) and the Thermal Fuse was bad. I replaced the fuse, cleaned the vent, and made sure that flexible vent tubing in the back was operational (not restricted). Yea- Dryer works.... for two days -- (However, Clothes were uncommonly hot after cycle and Dampness feature seemed overly sensitive) Dryer obviously got too hot again and Thermal Fuse did its job but now my dryer is down again. What other components would you suggest checking or replacing?
UPDATE- Found no other problems so I replaced the Thermal Fuse again. Yea, Dryer Runs. Still Clothes are Hot and Dampness feature adds time. Ran 4 loads of laundry and Dryer quit again.
Fan motor is running, I checked all other Thermal components for continuity (Thermal Cut Off, High Limit Thermostat/Thermistor, and the Heater Element) All OK! The only thing that continues to happen is Thermal Fuse blows.
Are there any other Dryer components that could be causing this problem? Is a blocked vent the only option? Inside dyer is completely clean. Dryer Hose from Dryer to wall is completely clean, Wall vent is clean as far as I can see. If this is the ONLY possible answer, my next step is to “snake” the wall vent to the outside.
Any other suggestions?
Ads By Google
Related Models
Whirlpool WED9200SQ0 ELECTRIC DRYER
Whirlpool WED9200SQ1 ELECTRIC DRYER
Whirlpool WED9200SQ2 ELECTRIC DRYER
Whirlpool WED9250WL0 27" ELECTRIC DRYER
Whirlpool WED9250WL1 27" ELECTRIC DRYER
Whirlpool WED9250WR0 27" ELECTRIC DRYER
Whirlpool WED9250WR1 27" ELECTRIC DRYER
Whirlpool WED9250WW0 27" ELECTRIC DRYER
Whirlpool WED9250WW1 27" ELECTRIC DRYER
Whirlpool WED9270XL0 27" ELECTRIC DRYER
Whirlpool WED9270XL1 27" ELECTRIC DRYER
Whirlpool WED9270XL2 27" ELECTRIC DRYER
Whirlpool WED9270XR0 27" ELECTRIC DRYER
Whirlpool WED9270XR1 27" ELECTRIC DRYER
Whirlpool WED9270XR2 27" ELECTRIC DRYER
Whirlpool WED9270XW0 27" ELECTRIC DRYER
Whirlpool WED9270XW1 27" ELECTRIC DRYER
Whirlpool WED9270XW2 27" ELECTRIC DRYER
Whirlpool WED9300VU0 ELECTRIC DRYER
Whirlpool WED9300VU1 ELECTRIC DRYER
Whirlpool WED9371YL0 27" ELECTRIC DRYER
Whirlpool WED9371YW0 27" ELECTRIC DRYER
Whirlpool WED9400SB0 ELECTRIC DRYER
Whirlpool WED9400SB1 ELECTRIC DRYER
Whirlpool WED9400ST0 ELECTRIC DRYER
Whirlpool WED9400ST1 ELECTRIC DRYER
Whirlpool WED9400SU0 ELECTRIC DRYER
Whirlpool WED9400SU1 ELECTRIC DRYER
Whirlpool WED9400SU2 ELECTRIC DRYER
Whirlpool WED9400SW0 ELECTRIC DRYER
Whirlpool WED9400SW1 ELECTRIC DRYER
Whirlpool WED9400SW2 ELECTRIC DRYER
Whirlpool WED9400SZ0 ELECTRIC DRYER
Whirlpool WED9400SZ1 ELECTRIC DRYER
Whirlpool WED9400SZ2 ELECTRIC DRYER
Whirlpool WED9400VE0 ELECTRIC DRYER
Whirlpool WED9400VE1 ELECTRIC DRYER
Whirlpool WED9450WL0 ELECTRIC DRYER
Whirlpool WED9450WL1 ELECTRIC DRYER
Whirlpool WED9450WR0 ELECTRIC DRYER
Whirlpool WED9450WR1 ELECTRIC DRYER
Whirlpool WED9450WW0 ELECTRIC DRYER
Whirlpool WED9450WW1 ELECTRIC DRYER
Whirlpool WED9470WL1 ELECTRIC DRYER
Whirlpool WED9470WR1 ELECTRIC DRYER
Whirlpool WED9470WW1 ELECTRIC DRYER
Whirlpool WED94HEXL0 DRYER
Whirlpool WED94HEXL1 27" ELECTRIC DRYER
Whirlpool WED94HEXR0 DRYER
Whirlpool WED94HEXR1 27" ELECTRIC DRYER
Whirlpool WED94HEXW0 DRYER
Whirlpool WED94HEXW1 27" ELECTRIC DRYER
Whirlpool WED9500TC0 ELECTRIC DRYER
Whirlpool WED9500TC1 ELECTRIC DRYER
Whirlpool WED9500TC2 ELECTRIC DRYER
Whirlpool WED9500TU0 ELECTRIC DRYER
Whirlpool WED9500TU1 ELECTRIC DRYER
Whirlpool WED9500TW0 ELECTRIC DRYER
Whirlpool WED9500TW1 ELECTRIC DRYER
Whirlpool WED9500TW2 ELECTRIC DRYER
Whirlpool WED9500TW3 ELECTRIC DRYER
Whirlpool WED9550WL0 ELECTRIC DRYER
Whirlpool WED9550WL1 ELECTRIC DRYER
Whirlpool WED9550WR0 ELECTRIC DRYER
Whirlpool WED9550WR1 ELECTRIC DRYER
Whirlpool WED9550WW0 ELECTRIC DRYER
Whirlpool WED9550WW1 ELECTRIC DRYER
Whirlpool WED95HEXL0 DRYER
Whirlpool WED95HEXL1 27" ELECTRIC DRYER
Whirlpool WED95HEXR0 DRYER
Whirlpool WED95HEXR1 27" ELECTRIC DRYER
Whirlpool WED95HEXW0 DRYER
Whirlpool WED95HEXW1 27" ELECTRIC DRYER
Whirlpool WED9600SU0 ELECTRIC DRYER
Whirlpool WED9600TA0 27" ELECTRIC DRYER
Whirlpool WED9600TA1 27" ELECTRIC DRYER
Whirlpool WED9600TA2 27" ELECTRIC DRYER
Whirlpool WED9600TB0 27" ELECTRIC DRYER
Whirlpool WED9600TB1 27" ELECTRIC DRYER
Whirlpool WED9600TU0 27" ELECTRIC DRYER
Whirlpool WED9600TU1 27" ELECTRIC DRYER
Whirlpool WED9600TW0 27" ELECTRIC DRYER
Whirlpool WED9600TW1 27" ELECTRIC DRYER
Whirlpool WED9600TW2 27" ELECTRIC DRYER
Whirlpool WED9600TZ0 27" ELECTRIC DRYER
Whirlpool WED9610XW0 27" ELECTRIC DRYER
Whirlpool WED9750WL0 27" ELECTRIC DRYER
Whirlpool WED9750WR0 27" ELECTRIC DRYER
Whirlpool WED9750WW0 27" ELECTRIC DRYER
Whirlpool WED97HEXL0 ELECTRIC DRYER
Whirlpool WED97HEXL1 27" ELECTRIC DRYER
Whirlpool WED97HEXL2 27" ELECTRIC DRYER
Whirlpool WED97HEXR0 ELECTRIC DRYER
Whirlpool WED97HEXR1 27" ELECTRIC DRYER
Whirlpool WED97HEXR2 27" ELECTRIC DRYER
Whirlpool WED97HEXW0 ELECTRIC DRYER
Whirlpool WED97HEXW1 27" ELECTRIC DRYER
Whirlpool WED97HEXW2 27" ELECTRIC DRYER
White Westinghouse WEF303PHDA White Westinghouse/electric Range
White Westinghouse WEF303PHDB White Westinghouse/electric Range
White Westinghouse WEF303PHWA White Westinghouse/electric Range
White Westinghouse WEF303PHWB White Westinghouse/electric Range
White Westinghouse WEF311SHDA White Westinghouse/electric Range
White Westinghouse WEF311SHWA White Westinghouse/electric Range
Frigidaire WEF322BADA Wwh(v1) / Electric Range
Frigidaire WEF322BADB Wwh(v1) / Electric Range
Frigidaire WEF322BADC Wwh(v2) / Electric Range
Frigidaire WEF322BADD Wwh(v1) / Electric Range
Frigidaire WEF322BAWA Wwh(v2) / Electric Range
Frigidaire WEF322BAWB Wwh(v3) / Electric Range
Frigidaire WEF322BAWC Wwh(v4) / Electric Range
Frigidaire WEF322BAWD Wwh(v2) / Electric Range
Frigidaire WEF322BEDA Wwh(v1) / Electric Range
Frigidaire WEF322BEDB Wwh(v1) / Electric Range
Frigidaire WEF322BEWA Wwh(v2) / Electric Range
Frigidaire WEF322BEWB Wwh(v2) / Electric Range
Frigidaire WEF322BEWC Frg(v0) / Electric Range
Frigidaire WEF322SADA Wwh(v1) / Electric Range
Frigidaire WEF322SADB Wwh(v1) / Electric Range
Frigidaire WEF322SADC Wwh(v5) / Electric Range
  #2 (permalink)
Old 02-19-2009, 02:28 PM
Senior Expert
APP Volunteer
denman is a glorious beacon of light
Default
Model Search
Here is a tech sheet that may help
https://www.servicematters.com/docs/...0W10110638.pdf
Air flow or heat control can blow the fuse.
Any thing that restricts air flow can cause the fuse to blow
Possible causes I can think of are
1. Dirty vent
2. Vent's exterior flaps not opening
3. Loose or broken blower wheel. Though usually they will make a racket
4. Dirty lint filter. If you use fabric softener it can coat the screen and drastically reduce air flow. Has to be cleaned with soap and water.
Vent Check
Undo the dryer from the exhaust
Run a load
If the load dries correctly then you have a vent problem.
Clean/check the vent system. Make sure the outside louvers open fully.
If you do not want lint in the house.
Take a pair of pantyhose, put one leg into the other and attach this to the dryer exhaust.
Leave enough room behind the dryer so it can blow out like a windsock.
Run a load.
Both the above will allow you to check the air flow and temp.
Also the above is NOT recommended for a gas dryer due to possible carbon monoxide problems.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
RCA Dryer Overheating dgstiens Dryer Repair 7 09-14-2009 05:46 AM
Dryer Overheating dgholmes03 Dryer Repair 3 05-29-2009 06:47 AM
Dryer Overheating jtowntbo5@yahoo.com Dryer Repair 4 03-14-2009 08:41 AM
Dryer Overheating? RogerB Dryer Repair 18 07-07-2008 12:20 PM
Whirlpool oven overheating rovingj Oven Repair (including Ranges and Cooktops) 3 04-24-2008 05:32 PM
