fathrof9
#1 Posted : Wednesday, February 18, 2009 4:34:32 PM(UTC)
fathrof9
Dryer has new igniter,coils, but still won't ignite/heat. Any suggestions??
What is the most common cure?
TechnicianBrian
#2 Posted : Wednesday, February 18, 2009 5:40:39 PM(UTC)
TechnicianBrian
Do you know if voltage is going to the burner assembly? If the igniter isn't glowing at all, I would suspect, your high limit thermostat (AP3084674) or the thermal fuse (AP3132867) behind the rear panel has failed. Try bypassing each one at a time by sliding the ends of the connectors together and see if the unit starts to heat. This is a temporary method to test and should not be used as a permanent fix.
fathrof9
#3 Posted : Thursday, February 19, 2009 4:49:35 AM(UTC)
fathrof9
thank you, will try today.
