| » dryer wont start |
It sounds like a bad motor, or a broken belt. I would really need a motel # to tell for sure. Tom ********************************************
Could be the belt has broken or the centrifugal switches
That you have heat is an indication of this. The motor has centrifugal switches on it. When the motor rotates they close One switch completes the circuit to the heating coils. So if the motor does not rotate you should not have heat unless the switch is messed up. The other switch disconnects the start winding in the motor. If the mechanism that actuates these switches is broken or binding it will hold the switches closed and you can then get heat and the motor will not start.
__________________
| Display Modes | |
| dryer wont start | CHRIS KAKATES | Dryer Repair | 1 | 02-17-2010 04:13 PM |
| dryer wont start | Merlin | Dryer Repair | 3 | 12-07-2009 05:41 PM |
| Gas dryer wont start | nikita | Dryer Repair | 1 | 07-21-2009 11:09 AM |
| dryer wont start | asguttx | Dryer Repair | 2 | 02-25-2009 04:21 AM |
| dryer wont start | phyllis | Dryer Repair | 5 | 10-21-2008 02:24 PM |
