Discuss
How to lift dryer top
 in
Dryer Repair
I need to replace the gas dryer door switch.The existing switch has lost its spring action and does'nt stop the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » How to lift dryer top
  #1 (permalink)
Old 06-01-2011, 11:49 AM
Junior Member
noto is on a distinguished road
Default How to lift dryer top
Model Number: tgdx604jq2   Brand: Estate   Age: 5 - 10 years
spring action and does'nt stop the drum from turning when the door is opened.How do i lift the top.toaccess the switch.
Ads By Google
Related Models
Whirlpool TGDX640EQ0
Whirlpool TGDX640EQ1
Whirlpool TGDX640EQ2
Whirlpool TGDX640EQ3
Whirlpool TGDX640JQ0
Whirlpool TGDX640JQ1
Whirlpool TGDX640JQ2
Whirlpool TGDX640JQ3 29"gas Dryer
Whirlpool TGDX640PQ0 29" Gas Dryer
Whirlpool TGDX640PQ1 29"gas Dryer
Tappan TGF303AWA Tappan/gas Range
Tappan TGF303BWA Tappan/gas Range
Tappan TGF303BWB Tappan/gas Range
Tappan TGF303BWC Tappan/gas Range
Frigidaire TGF303BWD Tappan/range
Tappan TGF303BWE Tappan/range
Tappan TGF317AUA Tappan/range
Tappan TGF317AUB Tappan/gas Range
Tappan TGF317AWA Tappan/range
Tappan TGF317AWB Tappan/gas Range
Tappan TGF317BUA Tappan/gas Range
Tappan TGF317BUB Tappan/gas Range
Tappan TGF317BUC Tappan/gas Range
Tappan TGF317BWA Tappan/gas Range
Tappan TGF317BWB Tappan/gas Range
Tappan TGF317BWC Tappan/gas Range
Tappan TGF317DUA Tappan/gas Range
Tappan TGF317DUB Tappan/gas Range
Tappan TGF317DUC Tappan/range
Tappan TGF317DWA Tappan/gas Range
Tappan TGF317DWB Tappan/gas Range
Tappan TGF317DWC Tappan/range
Tappan TGF317DWD Tappan/range
Tappan TGF317DWE Tappan/range
Tappan TGF317ESA Tappan/range
Tappan TGF317ESB Tappan/range
Tappan TGF317ESC Tappan/range
Tappan TGF317ESD Tappan/range
Tappan TGF320DUA Tappan/gas Range
Tappan TGF320DWA Tappan/gas Range
Tappan TGF320DWB Tappan/range
Tappan TGF320DWC Tappan/range
Tappan TGF324BHDD Tappan/gas Range
Frigidaire TGF324BHWA
Frigidaire TGF324BHWB
Tappan TGF324BHWC Tappan/range
Tappan TGF324BHWD Tappan/gas Range
Tappan TGF324BHWE Tappan/gas Range
Tappan TGF324WHSD Tappan/gas Range
Tappan TGF326WHSD Tappan/gas Range
Tappan TGF326WHSE Tappan/gas Range
Tappan TGF326WHTD Tappan/gas Range
Tappan TGF326WHTE Tappan/gas Range
Frigidaire TGF330WCDA Tap(v1) / Gas Range
Frigidaire TGF330WCDB Tap(v1) / Gas Range
Frigidaire TGF330WCDC Tap(v1) / Gas Range
Frigidaire TGF330WCDD Tap(v1) / Gas Range
Frigidaire TGF330WCDE Tap(v1) / Gas Range
Frigidaire TGF330WCWA Tap(v2) / Gas Range
Frigidaire TGF330WCWB Tap(v2) / Gas Range
Frigidaire TGF330WCWC Tap(v2) / Gas Range
Frigidaire TGF330WCWD Tap(v2) / Gas Range
Frigidaire TGF330WCWE Tap(v2) / Gas Range
Frigidaire TGF331SCDA Tap(v1) / Gas Range
Frigidaire TGF331SCDB Tap(v1) / Gas Range
Frigidaire TGF331SCDC Tap(v1) / Gas Range
Frigidaire TGF331SCWA Tap(v2) / Gas Range
Frigidaire TGF331SCWB Tap(v2) / Gas Range
Frigidaire TGF331SCWC Tap(v2) / Gas Range
Frigidaire TGF332BCDA Tap(v1) / Gas Range
Frigidaire TGF332BCDB Tap(v1) / Gas Range
Frigidaire TGF332BCDC Tap(v1) / Gas Range
Frigidaire TGF332BCDD Tap(v1) / Gas Range
Frigidaire TGF332BCDE Tap(v1) / Gas Range
Frigidaire TGF332BCWA Tap(v2) / Gas Range
Frigidaire TGF332BCWB Tap(v2) / Gas Range
Frigidaire TGF332BCWC Tap(v2) / Gas Range
Frigidaire TGF332BCWD Tap(v2) / Gas Range
Frigidaire TGF332BCWE Tap(v2) / Gas Range
Frigidaire TGF334BCDA Tap(v1) / Gas Range
Frigidaire TGF334BCDB Tap(v1) / Gas Range
Frigidaire TGF334BCDC Tap(v1) / Gas Range
Frigidaire TGF334BCDD Tap(v2) / Gas Range
Frigidaire TGF334BCDE Tap(v1) / Gas Range
Frigidaire TGF334BCDF Tap(v1) / Gas Range
Frigidaire TGF334BCDG Tap(v1) / Gas Range
Frigidaire TGF334BCDH Tap(v1) / Gas Range
Frigidaire TGF334BCWA Tap(v2) / Gas Range
Frigidaire TGF334BCWB Tap(v2) / Gas Range
Frigidaire TGF334BCWC Tap(v3) / Gas Range
Frigidaire TGF334BCWD Tap(v4) / Gas Range
Frigidaire TGF334BCWE Tap(v2) / Gas Range
Frigidaire TGF334BCWF Tap(v2) / Gas Range
Frigidaire TGF334BCWG Tap(v2) / Gas Range
Frigidaire TGF334BCWH Tap(v2) / Gas Range
Frigidaire TGF334WFSA Tap(v0) / Gas Range
Frigidaire TGF334WFSB Tap(v0) / Gas Range
Frigidaire TGF334WFSC Tap(v0) / Gas Range
Frigidaire TGF334WFSD Tap(v0) / Range
Frigidaire TGF335BCDA Tap(v1) / Gas Range
Frigidaire TGF335BCDB Tap(v1) / Gas Range
Frigidaire TGF335BCDC Tap(v1) / Gas Range
Frigidaire TGF335BCDD Tap(v1) / Gas Range
Frigidaire TGF335BCDE Tap(v1) / Gas Range
Frigidaire TGF335BCWA Tap(v2) / Gas Range
Frigidaire TGF335BCWB Tap(v2) / Gas Range
Frigidaire TGF335BCWC Tap(v2) / Gas Range
Frigidaire TGF335BCWD Tap(v2) / Gas Range
Frigidaire TGF335BCWE Tap(v2) / Gas Range
Frigidaire TGF335CFSA Tap(v1) / Gas Range
Frigidaire TGF335CFTA Tap(v2) / Gas Range
Tappan TGF336ASA Tappan/gas Range
Tappan TGF336ASB Tappan/gas Range
Tappan TGF336ASC Tappan/gas Range
Tappan TGF336ASD Tappan/gas Range
Tappan TGF336ASE Tappan/gas Range
Tappan TGF336ASF Tappan/gas Range
Tappan TGF336ASG Tappan/gas Range
Tappan TGF336ASH Tappan/range
Tappan TGF336ASJ Tappan/range
  #2 (permalink)
Old 06-01-2011, 02:08 PM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Noto,
Remove the lint filter from the housing,on the top of the cabinet, you'll find 2 phillips head screws under the filter, remove the 2 screws. Insert a putty knife or small screwdriver into the seam between the dryer top and front panel and pry up and out, on each corner and the top will release from the retainer clips, and you can raise the top, to access the door switch and wiring. It'll be a tight squeeze, so you may want to remove the 2, 1/4 in. screws from the cabinet front flange, approximately 3 inches down from the top on the inside of the front panel.
*** make sure you unplug the power cord, or turn the power off to the dryer, before you start.***
That should get you where you need to be.
Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
how to lift cooktop hilly Oven Repair (including Ranges and Cooktops) 1 02-14-2011 05:45 AM
Lift Top To Replace Lid Switch tyates Washer Repair 1 08-31-2010 09:35 AM
How to lift glass top Carl S Oven Repair (including Ranges and Cooktops) 3 08-20-2010 02:36 PM
Microwave lift jcnelson Microwave Repair 2 03-10-2009 07:29 PM
Main top will not lift vornato Oven Repair (including Ranges and Cooktops) 6 12-07-2007 05:07 AM
