| » Maytag dryer turns and heats but clothes not dry |
Model Number: SDE3606AYW Brand: Maytag Age: 5 - 10 years
Have a Maytag dryer that takes many many times to get clothes dry. When you open dryer, it is hot, the thing turns but clothes do not get dry. Help?
Model SDE3606AYW Most common cause is a dirty vent system. Undo the dryer from the exhaust Run a load If the load dries correctly then you have a vent problem. Clean/check the vent system. Make sure the outside louvers open fully. If you do not want lint in the house. Take a pair of pantyhose, put one leg into the other and attach this to the dryer exhaust. Leave enough room behind the dryer so it can blow out like a windsock. Run a load. Both the above will allow you to check the air flow and temp.
__________________
| Display Modes | |
| whirlpool dryer turns on heats for 5 min and and keeps turning but not heating? | nimster64 | Dryer Repair | 16 | 08-04-2011 06:24 AM |
| dryer heats but not enough to dry the clothes | winkk017 | Dryer Repair | 3 | 11-16-2009 06:28 PM |
| My dryer only heats up when dry clothes are put in. | bravosoldier | Dryer Repair | 1 | 10-04-2009 09:26 PM |
| Dryer runs, turns, heats, but won't dry | nanatoabunch | Dryer Repair | 2 | 08-11-2009 06:38 PM |
| Dryer heats but not when clothes are in it | jmbenesch | Dryer Repair | 3 | 03-08-2009 08:41 AM |
