| » How do I get access to the inside of the dryer to replace belt |
Model Number: D710 Brand: Maytag Age: More than 10 years
The sides and back are all one unit with only a small inspection panel on the lower right side in the back. It appears the top may come off but I can find no screws, and the smae goes for the front. I need help.
Related Models |
Could find no info on listed Model Number but this may help
http://www.applianceaid.com/maytag-dryers.html Check out #18 to #22
__________________
At the front top, about an inch and a half in from each corner, are spring clips. Depress these clips with a putty knife, or similar flat item, as you apply upward pressure on the corresponding corner, and the top will tilt up and away to expose the screws holding the front of the cabinet to the sides. Before removing the front panel, unplug the machine. There's electric current going through the door switch.
__________________
Nemo malus felix |
| Display Modes | |
| How To Access And Replace Dryer Part #35001153 Microcomputer | EPYTER@OLYSIGNS.COM | Dryer Repair | 1 | 09-22-2009 03:36 PM |
| Access to replace dyer belt | chris74 | Dryer Repair | 1 | 08-19-2009 11:07 AM |
| Getting access to inside of Hotpoint dryer | hhamer | Dryer Repair | 2 | 07-18-2009 02:05 PM |
| dryer access to replace heating element | medley | Dryer Repair | 2 | 03-28-2009 05:14 AM |
| Access to dryer drive belt and pulleys | jmontgo | Dryer Repair | 14 | 02-02-2008 01:01 PM |
