| » Gas Dryer Heating some but not enough |
Model Number: 77455100 Brand: Kenmore Age: More than 10 years
I have an older Kenmore gas dryer. It does not seem to be heating as much as it should. It takes 2 to 3 45 min rounds to dry clothes. I have replaced the vent hose cleaned the lint trap out and the inside of the dryer front and back. Still same problem. Please help!!! Related Models |
Have you cleaned the vent inside the wall all the way to the outlet?
__________________
Professional appliance repair in Orange County, California. |
Disconnect the vent hose from the dryer, and using a meat thermometer, measure the highest temperature inside the dryer vent during the cycle. Do it for all possible temperature settings. Post the results and the complete model number of the dryer.
__________________
Probably 10 minutes to 15 minutes for each setting.
__________________
I hope you don't mind if I jump in on this one. My post is Must cycle multiple times to get clothes dry . This is exactly the same problem I am having with a 5 yr old Kenmore. I did the meat thermometer check. It would get as high as ~140 F then the gas would shut off. The temp would get below 120F (lowest temp on my thermometer), gas would come back on. The temp would reach 140F then the gas would shut off. I let it cycle like this a couple of times. The setting was on Normal, timed dry. My serial number is 110.73942101 .
Cotton High - ~150F, 1 cycle then shut down. Have to reset timer to restart Normal Med High - 140F, multiple cycles. Perm Press Med - 122F, Multiple cycles. Ultra Delicate Xtra-Low - ~110F Multiple cycles. (Thermometers scale starts at 120F, had to interpolate). Last edited by Windemere166 : 02-22-2009 at 07:05 AM. |
Quote:
Did you run a full load with the vent hose disconnected from the dryer? If you did what was the result? If you did not then do it once and post the result. The result for the "Cotton High" setting leads to suspicion of failure with the gas valve coils. Gene.
__________________
| Display Modes | |
| Dryer not heating | rcabalo | Dryer Repair | 2 | 11-26-2009 09:52 AM |
| dryer not heating | iyacko | Dryer Repair | 2 | 08-26-2009 12:50 PM |
| dryer not heating | ecubulldog | Dryer Repair | 1 | 07-05-2009 07:40 AM |
| Dryer not Heating | stompy27 | Dryer Repair | 0 | 11-05-2008 06:06 AM |
| Gas dryer not heating | Penthor | Dryer Repair | 3 | 02-17-2008 08:56 AM |
