sdyak
#1 Posted : Monday, May 30, 2011 1:47:59 PM(UTC)
sdyak
I have Maytag Gas dryer (MDGB850WQ0) which has no heat. Unit is under warrenty so they came out and changed the thermal cut off limit and hight limit thermoster and heat was back. Then the next use on the second load the heat cut out again. The tech before mentioned the vent so I went ahead and cleaned it out. Since I watched the tech, I figured I change out the parts. One of the two parts ohm'd out good the other has an open. The part number on the failed unit is 3977394, which when I look it up pops up the the thermal/high limit kit for an electric dryer (my part matches the picture). The bulkhead parts diagram (MDGB850WQ0) shows the part number as AP3866211, unfortunitley no picture. So, are these the gas dryer and the electric dryer parts compatible or did the tech put the wrong part in????
Thanks in advance
sdyak
#2 Posted : Wednesday, June 1, 2011 6:18:43 PM(UTC)
sdyak
Thanks in advance
Did a ooops on the model number it's MGDB850WQ0, discovered during chat, which I was able to see a picture of the one called out in drawing and it looks like the wrong part was put in. Correct parts have now been ordered.
Maytag Gas Dryer - no heat (Dryer Repair)
by cav57 12/25/2011 2:43:59 PM(UTC)
Maytag Gas Dryer - No Heat - Intermittent (Dryer Repair)
by backbeat 2/2/2010 7:19:48 AM(UTC)
Maytag Gas Dryer - No heat Issue... (Dryer Repair)
by dsmstorm 11/25/2009 4:04:03 PM(UTC)
