Discuss
Too Hot not shutting off heat
 in
Dryer Repair
My dryer was not dring clothes very quickly and I put off cleaning the vent. One day it got so
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Too Hot not shutting off heat
  #1 (permalink)
Old 02-13-2009, 12:06 PM
Junior Member
toddholmes is on a distinguished road
Default Too Hot not shutting off heat
Model Number: MDE9557AYW   Brand: Maytag   Age: 5 - 10 years
My dryer was not dring clothes very quickly and I put off cleaning the vent. One day it got so hot that it almost burned the clothes and then quit. It wouldn't run at all. I used to own a heating shop so I figured that the dryer probably worked something like a furnace w/ high limits and a fusible link. Once I figured out how to get accsess and found a schematic (Maytag's site was so un helpful that they actually told me that they didn't have a model w/ my number???!!!!) I found the the thermal fuse and it didn't have continuity. I cleaned out the vent and found that it was stuffed almost solid. So I surmised that the clogged vent had caused the thermal fuse to melt down. I replaced it and the dryer worked....except that it was still getting really HOT. So I replaced the thermostat/High Limit. It still seemed too hot and seemed like it continued to power the element even w/ the door open if there was still "time" on the Control knob. It didn't shut off unless I turned the knob physically to "off". Now it has quit working at all again, except that when I set it to run and push the start button...I can hear a slight hummm but nothing else sems to be happening.?????Any thoughts???
Ads By Google
Related Models
Maytag MDE9557AYW Dryer - Ele
Maytag MDE9557AZA Dryer - Ele
Maytag MDE9557AZQ Dryer - Ele
Maytag MDE9557AZW Dryer - Ele
Maytag MDE9606AUW Dryer - Ele
Maytag MDE9606AYA Dryer - Ele
Maytag MDE9606AYQ Dryer - Ele
Maytag MDE9606AYW Dryer - Ele
Maytag MDE9606AZA Dryer - Ele
Maytag MDE9606AZQ Dryer - Ele
Maytag MDE9606AZW Dryer - Ele
Maytag MDE9700AYM Dryer - Ele
Maytag MDE9700AYQ Dryer - Ele
Maytag MDE9700AYW Dryer - Ele
Maytag MDE9700AZM Dryer - Ele
Maytag MDE9700AZW Dryer - Ele
Maytag MDE9706AYA Dryer - Ele
Maytag MDE9706AYW Dryer - Ele
Maytag MDE9706AZW Dryer - Ele
Maytag MDE9766AYW Dryer - Ele
Maytag MDE9766AZW Dryer - Ele
Maytag MDE9800AYQ Dryer - Ele
Maytag MDE9800AYW Dryer - Ele
Maytag MDE9800AZQ Dryer - Ele
Maytag MDE9800AZW Dryer - Ele
Maytag MDE9806AYA Dryer - Ele
Maytag MDE9806AYW Dryer - Ele
Maytag MDE9806AZW Dryer - Ele
Maytag MDE9876AYW Dryer - Ele
Maytag MDET236AYW Dryer - Ele
Maytag MDET236AZW Dryer - Ele
Maytag MDET336AYW Dryer - Ele
Maytag MDET336AZW Dryer - Ele
Maytag MDET446AYW Dryer - Ele
Maytag MDET446AZW Dryer - Ele
Maytag MDG100PN1 Dryer - Gas
Maytag MDG100PN1L Dryer - Gas
Maytag MDG100PN1W Dryer - Gas
Maytag MDG10CSAAL Dryer - Gas
Maytag MDG10CSAAW Dryer - Gas
Maytag MDG10CSABL Dryer - Gas
Maytag MDG10CSABW Dryer - Gas
Maytag MDG10CSAGL Dryer - Gas
Maytag MDG10CSAGW Dryer - Gas
Maytag MDG10CSAKL Dryer - Gas
Maytag MDG10CSEGL Dryer - Gas
Maytag MDG10CSEGW Dryer - Gas
Maytag MDG10DAAAL Dryer - Gas
Maytag MDG10DAAAW Dryer - Gas
Maytag MDG10DAABL Dryer - Gas
Maytag MDG10DAABW Dryer - Gas
Maytag MDG10MNAAW Dryer - Gas
International MDG10MNAGW Dryer - Gas
Maytag MDG10MNEGW Dryer - Gas
Maytag MDG10PDAAL Dryer - Gas
Maytag MDG10PDAAW Dryer - Gas
Maytag MDG10PDABL Dryer - Gas
Maytag MDG10PDABW Dryer - Gas
Maytag MDG10PDEGL Dryer - Gas
Maytag MDG10PDEGW Dryer - Gas
Maytag MDG10PRAAW Dryer - Gas
Maytag MDG10PSABW Dryer - Gas
Maytag MDG10PSAGL Dryer - Ele
Maytag MDG10PSAGW Dryer - Ele
Frigidaire MDG116RBW0 Frg(v1) / 27 " Gas Dryer
Frigidaire MDG116RBW1 Frg(v0) / Gas Dryer
Maytag MDG11CSAAL Dryer - Gas
Maytag MDG11CSAAW Dryer - Gas
Maytag MDG11CSABW Dryer - Gas
Maytag MDG11CSAGL Dryer - Gas
Maytag MDG11CSAGW Dryer - Gas
Maytag MDG11CSEGL Dryer - Gas
Maytag MDG11CSEGW Dryer - Gas
Maytag MDG11MNAAW Dryer - Gas
Maytag MDG11MNAGW Dryer - Gas
Maytag MDG11MNEGW Dryer - Gas
Maytag MDG11PDAAL Dryer - Gas
Maytag MDG11PDAAW Dryer - Gas
Maytag MDG11PDABL Dryer - Gas
Maytag MDG11PDABW Dryer - Gas
Maytag MDG11PDAGL Dryer - Gas
Maytag MDG11PDAGW Dryer - Gas
Maytag MDG11PDEGL Dryer - Gas
Maytag MDG11PDEGW Dryer - Gas
Maytag MDG120P1HW Dryer - Gas
Maytag MDG120PHVW Dryer - Gas
Maytag MDG12CSAAL Dryer - Gas
Maytag MDG12CSAAW Dryer - Gas
Maytag MDG12CSABL Dryer - Gas
Maytag MDG12CSABW Dryer - Gas
Maytag MDG12CSAGW Dryer - Gas
Maytag MDG12CSEGW Dryer - Gas
Maytag MDG12MNAAW Dryer - Gas
Maytag MDG12MNAGW Dryer - Gas
Maytag MDG12MNEGW Dryer - Gas
Maytag MDG12PDAAL Dryer - Gas
Maytag MDG12PDAAW Dryer - Gas
Maytag MDG12PDABL Dryer - Gas
Maytag MDG12PDABW Dryer - Gas
Maytag MDG12PDBAL Dryer - Gas
Maytag MDG12PDBAW Dryer - Gas
Maytag MDG12PDBBL Dryer - Gas
Maytag MDG12PDBBW Dryer - Gas
Maytag MDG12PRAAW Dryer - Gas
Maytag MDG12PRBAW Dryer - Gas
Maytag MDG12PRBBW Dryer - Gas
Maytag MDG12PSABW Dryer - Gas
Maytag MDG12PSAGW Dryer - Gas
Maytag MDG12PSBAW Dryer - Gas
Maytag MDG12PSBBW Dryer - Gas
Maytag MDG13CSAAL Dryer - Gas
Maytag MDG13CSAAW Dryer - Gas
Maytag MDG13CSABW Dryer - Gas
Maytag MDG13CSAGW Dryer - Gas
Maytag MDG13CSAKL Dryer - Gas
Maytag MDG13CSEGW Dryer - Gas
Maytag MDG13MNAAW Dryer - Gas
Maytag MDG13PDAAL Dryer - Gas
Maytag MDG13PDAAW Dryer - Gas
Maytag MDG13PDABL Dryer - Gas
Last edited by toddholmes : 02-13-2009 at 03:39 PM. Reason: I don't even have to push the start button...as soon as I rotate the timer control to any cycle the element is on.
  #2 (permalink)
Old 02-13-2009, 01:36 PM
Senior Expert
APP Volunteer
denman is just really nice
Default
Here are your parts, includes a wiring diagram
Model MDE9557AYW
If the hum is coming from the motor, it may have bit the dust.
This may take two people
First try rotating the drum by hand, it should turn fairly easily.
Open the door
Hold the door switch closed
Push the start button while rotating the drum in the correct direction
Watch your knuckles in case it starts up
If the dryer starts up, odds are high that the motor is shot re: one of the windings has burned out.
It sounds like your earlier high heat problem may have been due to a grounded element. Could be it is either broken or it has sagged and touched the case. Check it either visually or with a meter.
__________________
  #3 (permalink)
Old 02-13-2009, 03:43 PM
Junior Member
Default
I further observed that the element is on and heat is coming out of the perforated plate as soon as i turn the control dial to anything but "off". This is with the door open.
  #4 (permalink)
Old 02-14-2009, 03:28 AM
Senior Expert
APP Volunteer
Default
Definitely sounds like a grounded element.
__________________
  #5 (permalink)
Old 02-14-2009, 03:30 AM
Senior Expert
APP Volunteer
Default
There is an outside chance that it is dropping the voltage and this is causing the motor problem.
If the heater is grounded, I would remove the wires to it (mark where they go).
Tape them up so they cannot short to the frame
Give it a try.
If it starts, then all you need is the heater.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
keeps shutting off marie hornung Dryer Repair 5 02-26-2010 01:35 PM
keeps shutting off marie hornung Dryer Repair 8 02-22-2010 04:35 PM
GE oven display and heat shutting off Jooced Oven Repair (including Ranges and Cooktops) 0 01-06-2010 08:38 AM
Help - Dryer keeps shutting off fiestyforties Dryer Repair 1 12-14-2009 01:59 AM
Gas Dryer heat shutting down thomasl Dryer Repair 1 04-13-2009 02:27 PM
