Discuss
dryer belt /gas
 in
Dryer Repair
need to know how to replace the belt on my gas dryer Ads By Google Related Models Amana  AGM479W2  Dryer
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » dryer belt /gas
  #1 (permalink)
Old 02-13-2009, 09:33 AM
Junior Member
diannepa is on a distinguished road
Default dryer belt /gas
Model Number: AGM479W2   Brand: Speed Queen   Age: 1 - 5 years
Ads By Google
Related Models
Amana AGM479W2 Dryer - Gas
Amana AGM499L Dryer - Gas
Amana AGM499L2 Dryer - Gas
Amana AGM499W Dryer - Gas
Amana AGM499W2 Dryer - Gas
Amana AGM584E Range - S/i Std Gas
Amana AGM584LL Range - S/i Std Gas
Amana AGM584WW Range - S/i Std Gas
Amana AGM585E Range - S/i Std Gas
Amana AGM585LL Range - S/i Std Gas
Amana AGM585WW Range - S/i Std Gas
Amana AGM639 Dryer - Gas
Amana AGM659 Dryer - Gas
Amana AGM679L2 Washer - Top Loading
Amana AGM679W Dryer - Gas
Amana AGM679W2 Dryer - Gas
Amana AGM699L Dryer - Gas
Amana AGM699L2 Dryer - Gas
Amana AGM699W Dryer - Gas
Amana AGM699W2 Dryer - Gas
General Electric AGN05LAG1 Room air conditioner
General Electric AGN05LBG1 Room air conditioner
General Electric AGN05LCG1 Room air conditioner
General Electric AGN05LHG1 Room air conditioner
General Electric AGN05LJG1 Room air conditioner
General Electric AGN06LAG1 Room air conditioner
General Electric AGN08FAG1 Room air conditioner
General Electric AGN08FBG1 Room air conditioner
General Electric AGN08FCM1 Room air conditioner
General Electric AGN08FDM1 Room air conditioner
General Electric AGN10AAG1 Room air conditioner
General Electric AGN10ABG1 Room air conditioner
General Electric AGN10ACG1 Room air conditioner
General Electric AGN12AAG1 Room air conditioner
General Electric AGN12ABG1 Room air conditioner
General Electric AGN12ACG1 Room air conditioner
General Electric AGN12ADG1 Room air conditioner
General Electric AGN14AAG1 Room air conditioner
General Electric AGN14AAG2 Room air conditioner
General Electric AGN14ABG1 Room air conditioner
General Electric AGN14ACG1 Room air conditioner
General Electric AGN18DAG1 Room air conditioner
General Electric AGN18DBG1 Room air conditioner
General Electric AGN18DBG2 Room air conditioner
General Electric AGN24DAD1 Room air conditioner
General Electric AGN24DAM1 Room air conditioner
Amana AGOD2750E Range - S/c S/i Ddraft Gas
Amana AGOD2750WW Range - S/c S/i Ddraft Gas
General Electric AGP05LAG1 Room air conditioner
General Electric AGP05LBG1 Room air conditioner
General Electric AGP05LCG1 Room air conditioner
General Electric AGP07LHG1 Room air conditioner
General Electric AGP07LJG1 Room air conditioner
General Electric AGP08AAG1 Room air conditioner
General Electric AGP08AAG2 Room air conditioner
General Electric AGP08FAG1 Room air conditioner
General Electric AGP08FBM1 Room air conditioner
General Electric AGP10AAG1 Room air conditioner
General Electric AGP10ABG1 Room air conditioner
General Electric AGP10ABG2 Room air conditioner
General Electric AGP10ACG1 Room air conditioner
General Electric AGP12AAG1 Room air conditioner
General Electric AGP12AAG2 Room air conditioner
General Electric AGP12ABG1 Room air conditioner
General Electric AGP12ACG1 Room air conditioner
General Electric AGP18DAD1 Room air conditioner
General Electric AGP18DBG1 Room air conditioner
General Electric AGP18DCG1 Room air conditioner
General Electric AGP18DCG2 Room air conditioner
General Electric AGP24DAD1 Room air conditioner
General Electric AGP24DBM1 Room air conditioner
General Electric AGP24DBM2 Room air conditioner
General Electric AGQ05LAG1 Room air conditioner
General Electric AGQ05LBG1 Room air conditioner
General Electric AGQ05LHG1 Room air conditioner
General Electric AGQ05LJG1 Room air conditioner
General Electric AGQ06LAG1 Room air conditioner
General Electric AGQ06LHG1 Room air conditioner
General Electric AGQ06LJG1 Room air conditioner
General Electric AGQ08AHG1 Room air conditioner
General Electric AGQ08AJG1 Room air conditioner
General Electric AGQ08FAM1 Room air conditioner
General Electric AGQ10AAG1 Room air conditioner
General Electric AGQ10AHG1 Room air conditioner
General Electric AGQ10AJG1 Room air conditioner
General Electric AGQ12AHG1 Room air conditioner
General Electric AGQ12AJG1 Room air conditioner
General Electric AGQ12DAG1 Room air conditioner
General Electric AGQ12DBG1 Room air conditioner
General Electric AGQ12DHG1 Room air conditioner
General Electric AGQ12DJG1 Room air conditioner
General Electric AGQ12DKG1 Room air conditioner
General Electric AGQ14AAG1 Room air conditioner
General Electric AGQ14AHG1 Room air conditioner
  #2 (permalink)
Old 02-13-2009, 08:09 PM
Junior Member
jimreaper is on a distinguished road
Default
See "anniesmomrocks". She had a similar question.
  #3 (permalink)
Old 02-14-2009, 01:01 PM
Senior Expert
APP Volunteer
kayakcrzy will become famous soon enough
Default
no, the grim reaper is not telling you correctly. let me help you out. first unplug the dryer. then take the 2 screws off the bottom panel. and then on the bottom of the top panel on the right and left side, there will be a 5/16th screw. remove them both, and then grab the bottom of the front panel and lift it out toward you, and when you get at a 45 degree angle the top will come out. then take the wires off the door switch, and remember where they go. if you have a drum light, remove those 2 wires to, and then set the front aside. now we have to take the blower housing assembly off. so on the right side of the front there will be a 5/16th screw about a foot down from the top on the right side, and another a foot below it on the right side, and then there will be 2 more screws on the left side in the same place. when you get those off, remove the whole assembly. you might want clean the blower area while you have it off. then you can put your new belt around the drum, rib side down, and put it around the motor pully, and then around the idler pully, and then turn the drum by hand to be sure that it is on correctly. if i were you, i would pull the drum out before you put the new belt on, and check the 2 drum rollers, and the idler pully wheel, a make sure they spin freely. tom ******************************************** - parts
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer belt jney1025 Dryer Repair 2 02-04-2010 12:26 PM
dryer belt nolasaints04 Dryer Repair 1 09-27-2009 05:42 PM
dryer belt htrimpe70 Dryer Repair 2 04-07-2009 06:02 AM
Dryer Tub Belt ColleenR Dryer Repair 0 07-26-2007 08:39 PM
how to put a belt on my dryer radracemom Dryer Repair 1 07-23-2007 04:47 PM
