Discuss
gas dryer
 in
Dryer Repair
dryer does not heat, i replaced the igniter because it had no continuity, it still does not fire. it appears
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » gas dryer
  #1 (permalink)
Old 07-30-2007, 08:46 AM
randy43 randy43 is offline
Junior Member
randy43 is on a distinguished road
Cool gas dryer
Model Number: LGR4634BQ1   Brand: Whirlpool   Age: 5 - 10 years
dryer does not heat, i replaced the igniter because it had no continuity, it still does not fire. it appears that it is not getting the right voltage to the igniter. any ideas
Related Models
Whirlpool LGR4634BQ1
Whirlpool LGR4634BQ2
Whirlpool LGR4634DQ0
Whirlpool LGR4634DQ1
Whirlpool LGR4634DZ0
Whirlpool LGR4634EQ0
Whirlpool LGR4634EQ1
Whirlpool LGR4634EQ2
Whirlpool LGR4634EQ3
Whirlpool LGR4634EW0
Whirlpool LGR4634EZ0
Whirlpool LGR4634EZ1
Whirlpool LGR4634EZ2
Whirlpool LGR4634EZ3
Whirlpool LGR4634JQ0
Whirlpool LGR4634JQ1
Whirlpool LGR4634JQ2
Whirlpool LGR4634JQ3 29" Gas Dryer
Whirlpool LGR4634JT0
Whirlpool LGR4634JT1
Whirlpool LGR4634JT2
Whirlpool LGR4634JT3 29" Gas Dryer
Whirlpool LGR4634JZ0
Whirlpool LGR4634JZ1
Whirlpool LGR4634PQ0 29" Gas Dryer
Whirlpool LGR4634PQ1 29" Gas Dryer
Whirlpool LGR4634PT0 29" Gas Dryer
Whirlpool LGR4634PT1 29" Gas Dryer
Whirlpool LGR5434AN0
Whirlpool LGR5434AW0
Whirlpool LGR5600HQ0
Whirlpool LGR5600HZ0
Whirlpool LGR5600JQ0
Whirlpool LGR5600JQ1
Whirlpool LGR5600JT0
Whirlpool LGR5600JT1
Whirlpool LGR5620KQ0
Whirlpool LGR5620KQ1
Whirlpool LGR5620KQ2 29"gas Dryer
Whirlpool LGR5624BN0
Whirlpool LGR5624BN1
Whirlpool LGR5624BN2
Whirlpool LGR5624BW0
Whirlpool LGR5624BW1
Whirlpool LGR5624BW2
Whirlpool LGR5624DQ0
Whirlpool LGR5624DQ1
Whirlpool LGR5624DW1
Whirlpool LGR5624DZ0
Whirlpool LGR5624DZ1
Whirlpool LGR5634AN0
Whirlpool LGR5634AQ0
Whirlpool LGR5634AQ1
Whirlpool LGR5634AQ2
Whirlpool LGR5634AW0
Whirlpool LGR5634DQ1
Whirlpool LGR5634EQ0
Whirlpool LGR5634EZ0
Whirlpool LGR5634LQ0
Whirlpool LGR5635LQ0 29"gas Dryer
Whirlpool LGR5635LQ1 29"gas Dryer
Whirlpool LGR5636DW0
Whirlpool LGR5636DW1
Whirlpool LGR5636EQ0
Whirlpool LGR5636EQ1
Whirlpool LGR5636EQ2
Whirlpool LGR5636EQ3
Whirlpool LGR5636EZ0
Whirlpool LGR5636EZ1
Whirlpool LGR5636EZ2
Whirlpool LGR5636EZ3
Whirlpool LGR5636JQ0
Whirlpool LGR5636JQ1
Whirlpool LGR5636JT0
Whirlpool LGR5636JT1
Whirlpool LGR5636KQ0
Whirlpool LGR5636KQ1
Whirlpool LGR5636KT0
Whirlpool LGR5636KT1
Whirlpool LGR5636LG0
Whirlpool LGR5636LQ0
Whirlpool LGR5636LQ1 29"gas Dryer
Whirlpool LGR5636LT0
Whirlpool LGR5636LT1 29"gas Dryer
Whirlpool LGR5636LW0
Whirlpool LGR5636PQ0 29"gas Dryer
Whirlpool LGR5636PQ1 29"gas Dryer
Whirlpool LGR5636PT0 29"gas Dryer
Whirlpool LGR5636PT1 29"gas Dryer
Whirlpool LGR5638AN0
Whirlpool LGR5638AN1
Whirlpool LGR5638AN2
Whirlpool LGR5638AN3
Whirlpool LGR5638AW0
Whirlpool LGR5638AW1
Whirlpool LGR5638AW2
Whirlpool LGR5638AW3
Whirlpool LGR5644AN0
Whirlpool LGR5644AN1
Whirlpool LGR5644AN2
Whirlpool LGR5644AW0
Whirlpool LGR5644AW1
Whirlpool LGR5644AW2
Whirlpool LGR5644EQ0
Whirlpool LGR5644EQ1
Whirlpool LGR5644EQ2
Whirlpool LGR5644EQ3
Whirlpool LGR5644EZ0
Whirlpool LGR5644EZ1
Whirlpool LGR5644EZ2
Whirlpool LGR5644EZ3
Whirlpool LGR5644JQ0
Whirlpool LGR5644JQ1
Whirlpool LGR5644JQ2
Whirlpool LGR5644JQ3 29" Gas Dryer
Whirlpool LGR5644JT0
Whirlpool LGR5644JT1
Whirlpool LGR5644JT2
Whirlpool LGR5644JT3 29" Gas Dryer
Whirlpool LGR5644PQ0 29" Gas Dryer
  #2 (permalink)
Old 07-31-2007, 01:12 AM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
randy43
Check the thermal fuse on the back of the dryer for the continuity and replace it together with the operational thermostat if it's open. The part number for the thermal fuse is AP3132867 and the part number for the thermostat is AP3131939
Good luck.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
