| » Amana Heat Relay Not Energized |
Model Number: NGD7200TW Brand: Amana Age: 1 - 5 years
Traced problem to the black heater relay on the main control board. Need to know what energizes this relay. Could the front panel control board be the culprit.
Most likely the problem is a bad PCB (#17 on the diagram).
- The PCB Part number: AP4045210 Here are the breakdown diagrams and Replacement parts for MAYTAG NGD7200TW10 27" GAS DRYER | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Replaced circuit board, now when going to start up, it shows an tS error, and won't start, I swapped back the old board, and now the error shows up with that one also, this is strange because, before no error codes showed up. The dryer started up and ran , but just never fired up. But did run. Now the error code shows up and it won't run at all. Checked the Thermister and it reads 10k ohms. Strange that no codes showed up at first, replaced with new board, code shows up. Swapped back to old board and now code reads with that one. any thoughts ?
The "tS" error code means "The dryer thermistor short sensed".
Check the wires from the thermistor to the control board. Make sure the vent system is not restricted and the lint screen is clean. Gene.
__________________
| Display Modes | |
| Dishwasher Solenoid Constantly Energized | schlescw | Dishwasher Repair | 6 | 06-07-2011 01:41 PM |
| LG WF 651 cold water solenoid constantly energized | McMaddles | Washer Repair | 0 | 11-23-2009 04:39 PM |
| Broiler element is energized! | richard_carter53 | Oven Repair (including Ranges and Cooktops) | 1 | 03-10-2009 04:45 PM |
| AMANA overload relay replacement | cc703 | Refrigerator & Freezer Repair | 2 | 04-24-2008 07:14 AM |
| dispeser always energized | mmich187 | Dishwasher Repair | 1 | 12-06-2007 05:29 PM |
