Discuss
Kenmore gas dryer don't heat
 in
Dryer Repair
Hello, I am a single mom who can't afford to hire someone so please help! I put above that
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kenmore gas dryer don't heat
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 11-09-2007, 07:56 AM
tinatinagirl5 tinatinagirl5 is offline
Junior Member
tinatinagirl5 is on a distinguished road
Default Kenmore gas dryer don't heat
Model Number: 11097274100   Brand: Kenmore   Age: 5 - 10 years
Hello, I am a single mom who can't afford to hire someone so please help! I put above that the dryer is 5 to 10 years old but I do not know how old it is for sure. I have a Kenmore Gas Dryer Model # 11097274100, Serial # MC0227481. Here is the story: The other day I shut the main power switch off in the house to wire a kitchen light. I turned the main power switch back on when I was done. I put clothes in my dryer and found out there is not heat but everything else works, so the clothes do not dry. I have been searching for an owners manual online and no luck. I looked elsewhere online but when they say check this or that I don't even know what the part looks like that they are talking about. The dryer also has the word "pilotless" on the front. So what I did was I flipped the dryer breaker off and on and off and on just to make sure...still no heat. Then I pulled off the bottom of the dryer hose vent and it was clear. Then I took the whole back panel off but I don't know what to look for. When I layed my head on the floor so I could see under the lowest panel of the dryer (on the bottom) I see tons of dust all over. I was going to stick my vacuum hose in it to suck up the dust but I don't know if I will get a shock or would be in any danger cause gas scares me cause I don't know much about it. I do have the dryer unplugged the the gas valve is still turned so it is parallel with the gas line so there is gas flow. I don't know what to do from here but I am really determined to fix this myself. It is rather ironic that it worked before I turned the main breaker off but didn't after I turned it back on. Any help is kindly appreciated! Any pictures or diagram of parts would help me too so I know what you are talking about. Thanks so so so so so much!!!!!!!!!!!! ...........Ok I am back, I vaccumed out all the dust inside, underneath all over, check all vents, washed the lint screen, put all back together still no heat.
Last edited by tinatinagirl5 : 11-09-2007 at 10:24 AM. Reason: I am just adding more info
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore gas dryer barbaby Dryer Repair 1 10-09-2007 02:09 PM
Kenmore Clothes Dryer No Heat -Model 110.62994101 HRichburg Dryer Repair 5 09-30-2007 09:20 AM
Intermittant heat from Kenmore Gas Dryer theoutcaste Dryer Repair 3 09-17-2007 08:47 AM
Kenmore runs but won't heat kbarr Dryer Repair 2 08-09-2007 04:26 PM
Kenmore dryer will not run appbaffled Dryer Repair 2 07-23-2007 06:40 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
