| » roper dryer repair |
Model Number: rel4422awo Brand: -brand- Age: Less than 1 year
I recently moved into a house where the dryer worked for a couple of loads and then simply would not turn on when a new load was placed inside. I do not know if the problem is in the switch or the moter. Everytime I press the switch nothing happens.
In order to provide the most accurate advise I need the complete model number of your dryer. You can find it on the door frame.
Please, post it as a new thread. Gene.
__________________
Professional appliance repair in Los Angeles, California. |
I have a roper dryer electric that I turned on when I went to work last night it dryed everything, My wife got up at 3 am and the dryer was still running but with no heat. I have it running now no heat.
Mod #MR5044615 I will be going to work in a little while, if you wouldn't mind sending help to my e mail, if not that is ok den44@juno.com Last edited by Dennis331 : 01-25-2008 at 05:21 PM. |
Hi Dennis,
What cycle did you use when it was running nonstop? Looks like instead of the model number you posted the serial number. Verify and repost it, please. Gene.
__________________
Roper dryer is Ser#REX3514PQ0
TYPE D433-ELE 2406028-FM54 It says the auto sense dry side of the dial, which is on the left side. Dennis Langer den44@juno.com Last edited by Dennis331 : 01-27-2008 at 07:02 AM. |
Hi Dennis,
On the same name plate where you found the serial number suppose to be the model number. Gene.
__________________
| Display Modes | |
| Roper Dryer will not run | TERRY38108 | Dryer Repair | 1 | 11-07-2007 05:21 PM |
| roper gas dryer spins but no heat | relvis | Dryer Repair | 1 | 09-19-2007 10:47 PM |
| Roper Dryer not working at all now | cpego123 | Dryer Repair | 2 | 09-19-2007 06:46 PM |
| Roper dryer - 95 volts on timer motor | jazbird1 | Dryer Repair | 1 | 08-10-2007 09:49 PM |
| Dryer repair | Doitmyself | Dryer Repair | 2 | 07-27-2007 02:13 PM |
