abron1
#1 Posted : Sunday, February 8, 2009 11:51:30 AM(UTC)
abron1
Hello,this is my 1st time using your site & I need your help.my dryer won't heat & i've got good voltage & dryer turns.book say's possible 1 of 2 fuses bad.problem is i don't have a instruction booklet to locate the fuses,could you please help.
kayakcrzy
#2 Posted : Monday, February 9, 2009 3:44:25 AM(UTC)
kayakcrzy
If the dryer runs, and does not heat, it will not be the limit switch. You, have to remove the top, and in the back up top is the high limit switch. Make sure the dryer is unplugged, and ohm it out. If it is good, you will have to check the element. But, alot of people say the dryer has power, but are not using a meter to check it. You need to check power, where the plug comes into the dryer. A dryer will run with 1/2 the power, but it won't heat. Tom ApplianceEducator.com
GE Dryer Not Heating - Model: GFDS140ED0WW (Dryer Repair)
by laflair13 3/1/2023 3:14:27 AM(UTC)
Frigidaire Dryer Not Heating - Still Tumbles (Dryer Repair)
by dryerhelp98765 9/18/2021 8:06:29 AM(UTC)
help with samsung dryer not heating : DV350AEW / XAA (Dryer Repair)
by Guest 3/18/2021 11:11:18 AM(UTC)
Kenmore 70 series gas dryer not heating (Dryer Repair)
by Gilmo211 12/29/2020 10:09:04 AM(UTC)
GE Dryer not heating up (Dryer Repair)
by Dryernoob 4/23/2020 10:55:51 AM(UTC)
Dryer Not Heating even tough Fuse and Heating Element is good (Dryer Repair)
by Mixter7958 3/17/2020 4:37:28 PM(UTC)
Dryer not heating, question about voltage drop. (Dryer Repair)
by Pmp816 2/3/2019 6:58:39 AM(UTC)
Amana dryer not heating (Dryer Repair)
by keepingwiththetimes 2/7/2018 2:53:54 PM(UTC)
Whirlpool dryer not heating (Dryer Repair)
by Oscarwray 9/29/2017 4:54:27 PM(UTC)
Maytagdryer Not heating (Dryer Repair)
by ApplianceRN 9/16/2017 12:48:37 PM(UTC)
Dryer not heating (Dryer Repair)
by hoymanj 8/3/2017 2:39:08 PM(UTC)
Maytag Dryer not heating with rattle noise (Dryer Repair)
by Glengc1 6/24/2017 4:09:37 PM(UTC)
Maytag dryer not heating (Dryer Repair)
by Jmr721 4/29/2017 12:11:59 PM(UTC)
Amana Dryer not heating (Dryer Repair)
by HnRmom 4/27/2017 6:09:54 PM(UTC)
by tcdegener@yahoo.com 11/10/2016 8:39:58 AM(UTC)
