Hi! My gas dryer heats and runs but timer does not advance when heating. Timer seems to advance okay when I have dryer running without heat. Read that thermostats could keep timer from advancing. Seem to have two cycling thermostats, Part #344395 and #343251 plus a third thermostat that I assume is a safety control. Do I need to replace both? Each of these cycling thermostats have three wire leads. Will the replacements have three connection ports? Thanks for any help.
