Discuss
dryer blowing thermal fuse on heating element
 in
Dryer Repair
Recently, I had to replace the drum rollers on this unit. Two weeks later dryer quit heating. Heating element broke,
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » dryer blowing thermal fuse on heating element
  #1 (permalink)
Old 05-21-2011, 09:37 PM
Junior Member
kents12 is on a distinguished road
Default dryer blowing thermal fuse on heating element
Model Number: LE6150XSNO   Brand: Whirlpool   Age: More than 10 years
Recently, I had to replace the drum rollers on this unit. Two weeks later dryer quit heating. Heating element broke, replaced it and found thermal fuse blown. Replaced thermal fuse and High limit thermostat. Dryer ran for one day or 4 loads, Fuse blew again. I had completely cleaned out unit and vent system and found some lint build up. Replaced fuse again along with cycling thermostat and thermal vent fuse and did not hook up to vent system, half way through first cycle the Fuse blew again. I understand this is a old unit but still functional, but what's next to look for? Drum seal? would it make it blow that quickly?
Related Models
Whirlpool LE6150XSW0 Residential Dryer
Whirlpool LE6150XSW1 Residential Dryer
Whirlpool LE6400XKW0 Residential Dryer
Whirlpool LE6400XPW0 Residential Dryer
Whirlpool LE6400XSW0 Residential Dryer
Whirlpool LE6405XPW0 Residential Dryer
Whirlpool LE6600XPW0 Residential Dryer
Whirlpool LE6600XSW0 Residential Dryer
Whirlpool LE6605XPW0 Residential Dryer
Whirlpool LE6605XPW1 Residential Dryer
Whirlpool LE6680XPW0 Residential Dryer
Whirlpool LE6680XSW0 Residential Dryer
Whirlpool LE6685XPW0 Residential Dryer
Whirlpool LE6685XPW1 Residential Dryer
Whirlpool LE6800XPW0 Residential Dryer
Whirlpool LE6800XSW0 Residential Dryer
Whirlpool LE6800XTG0
Whirlpool LE6800XTN0
Whirlpool LE6800XTW0 Residential Dryer
Whirlpool LE6805XPW0 Residential Dryer
Whirlpool LE6810XPW0 Residential Dryer
Whirlpool LE6810XSW0 Residential Dryer
Whirlpool LE6880XSW0 Residential Dryer
Whirlpool LE6880XSW1 Residential Dryer
Whirlpool LE6880XTW0 Residential Dryer
Whirlpool LE6880XTW1 Residential Dryer
Whirlpool LE7000XMW0 Residential Dryer
Whirlpool LE7000XMW1 Residential Dryer
Whirlpool LE7000XMW2 Residential Dryer
Whirlpool LE7000XPW0 Residential Dryer
Whirlpool LE7000XSW0 Residential Dryer
Whirlpool LE7000XTG0
Whirlpool LE7000XTN0
Whirlpool LE7000XTW0 Residential Dryer
Whirlpool LE7005XPW0 Residential Dryer
Whirlpool LE7010XPW0 Residential Dryer
Whirlpool LE7010XSW0 Residential Dryer
Whirlpool LE7080XSW0 Residential Dryer
Whirlpool LE7080XSW1 Residential Dryer
Whirlpool LE7080XTW0 Residential Dryer
Whirlpool LE7080XTW1 Residential Dryer
Amana LE7101LB DRYER- ELE
Amana LE7101WB DRYER- ELE
Amana LE7111LB DRYER- ELE
Amana LE7111LM DRYER- ELE
Amana LE7111WB DRYER- ELE
Amana LE7111WM DRYER- ELE
Amana LE7121LM DRYER- ELE
Amana LE7121WM DRYER- ELE
Amana LE7153LB DRYER- ELE
Amana LE7153LM DRYER- ELE
Amana LE7153WB DRYER- ELE
Amana LE7153WM DRYER- ELE
Amana LE7163LM DRYER- ELE
Amana LE7163WM DRYER- ELE
Whirlpool LE7680XMW0 Residential Dryer
Whirlpool LE7680XPW0 Residential Dryer
Whirlpool LE7680XSW0 Residential Dryer
Whirlpool LE7680XSW1 Residential Dryer
Whirlpool LE7680XSW2 Residential Dryer
Whirlpool LE7685XPW0 Residential Dryer
Whirlpool LE7685XPW1 Residential Dryer
Whirlpool LE7700XWW0 Residential Dryer
Whirlpool LE7760XWW0 Residential Dryer
Whirlpool LE7800XKW0 Residential Dryer
Whirlpool LE7800XKW1 Residential Dryer
Whirlpool LE7800XMW0 Residential Dryer
Whirlpool LE7800XMW1 Residential Dryer
Whirlpool LE7800XMW2 Residential Dryer
Whirlpool LE7800XPW0 Residential Dryer
Whirlpool LE7800XSN2 ELECTRIC DRYER
Whirlpool LE7800XSW0 Residential Dryer
Whirlpool LE7800XSW1 Residential Dryer
Whirlpool LE7800XSW2 Residential Dryer
Whirlpool LE7800XSW3 Residential Dryer
Whirlpool LE7800XW2 ELECTRIC DRYER
Whirlpool LE7805XPW0 Residential Dryer
Whirlpool LE7810XPW0 Residential Dryer
Amana LE8107L2 WASHER-TOP LOADING
Amana LE8107W2 DRYER- ELE
Amana LE8207L2 WASHER-TOP LOADING
Amana LE8207L3 WASHER-TOP LOADING
Amana LE8207W2 DRYER- ELE
Amana LE8207W2B DRYER- ELE
Amana LE8207W3 DRYER- ELE
Amana LE8217L2 DRYER- ELE
Amana LE8217W2 DRYER- ELE
Amana LE8267L2 WASHER-TOP LOADING
Amana LE8267W2 DRYER- ELE
Amana LE8317L2 DRYER- ELE
Amana LE8317W2 DRYER- ELE
Amana LE8317W2B DRYER- ELE
Amana LE8327W DRYER- ELE
Amana LE8367L2 WASHER-TOP LOADING
Amana LE8367W2 DRYER- ELE
Amana LE8407L2 DRYER- ELE
Amana LE8407W DRYER- ELE
Amana LE8407W2 DRYER- ELE
Amana LE8457L2 DRYER- ELE
Amana LE8457W DRYER- ELE
Amana LE8457W2 DRYER- ELE
Amana LE8467L2 DRYER- ELE
Amana LE8467W2 DRYER- ELE
Amana LE8507W DRYER- ELE
Amana LE8517L2 DRYER- ELE
Amana LE8517W2 DRYER- ELE
Amana LE8517W2B DRYER- ELE
Amana LE8567L2 DRYER- ELE
Amana LE8567W2 DRYER- ELE
Whirlpool LE8600XWW0 Residential Dryer
Amana LE8607L2 DRYER- ELE
Amana LE8607W DRYER- ELE
Amana LE8607W2 DRYER- ELE
Whirlpool LE8650XWW0 Residential Dryer
Whirlpool LE8860XWQ0 Residential Dryer
Amana LE9002 WASHER-TOP LOADING
Amana LE9002 DRYER- ELE
Amana LE9012 WASHER-TOP LOADING
Whirlpool LE9100XTW0 Residential Dryer
Whirlpool LE9100XTW1 Residential Dryer
  #2 (permalink)
Old 05-22-2011, 05:28 AM
Senior Expert
APP Volunteer
kayakcrzy will become famous soon enough
Default
Well you have replaced everything. But, I can think of one thing, that you did not mention. Usually the thermal fuse blows due to too hot conditions, which would either be a vent situation, or a bad cycling thermostat. You said, you have taken care of both. But, there could be more air flow blockage. I have experienced this problem many times, and here is what you have to do. I want you to take off, where the lint filter goes in. So, when you pull the lint filter out, you remove the 2 screws, and then pop the top up. Then go to the back of the dryer, and take the back off. You will see the vent housing on the left. Remove the four 5/16th of an inch screws, and pull off the vent housing. If it is clogged up, clean, and then put in a new thermal fuse, if you haven't already, and run some cycles with the vent hose off. If it works, hook up the vent hose. If it blows after that then the issue is the vent hose to the outside. Tom ********************************************
  #3 (permalink)
Old 05-22-2011, 08:49 PM
Junior Member
I have already completely took off vent area and cleaned all, plus ran a snake through the house vent piece. I did put in new thermal fuse and did not hook up to house vent system and the fuse blew less than half of a cycle. After replacing basically all electronic sensors and fuses, making sure there is no blockage, Im wondering if there is something wrong with the new high limit thermostat or cycling sensor. I checked that new heating element is not touching housing sides and open ohms. Plus I have changed the high limit thermostat each time I replaced the thermal fuse since you buy them in a set. What next?
  #4 (permalink)
Old 05-23-2011, 01:36 PM
Senior Expert
APP Volunteer
Default
If you did not take the vent housing off like I said, there is no snake that can get to it. 99% of the times, new parts, are usually not the problem. Tom ********************************************
  #5 (permalink)
Old 05-24-2011, 02:18 PM
Junior Member
Default
I did take vent housing off and cleaned all around the fan , housing, screen, drum, motor, every thing, plus ran the snake thru the vent system of my house. Sorry if you misunderstood what all I have cleaned. There is no vent blockage at all. The fan seemed secure to shaft. The felt piece around the drum probably needs replaced, but would that cause my fuse to blow
  #6 (permalink)
Old 05-24-2011, 03:45 PM
Senior Expert
APP Volunteer
Default
It just depends if alot of air is coming out. I have seen them pretty ripped up, and work just fine. The only thing I could think of maybe the motor is drawing high amps, and knocking out the thermal fuse. It could also be the timer having a bad contact, and shorting out, and blowing the thermal fuse. These 2 things are not easy to detect. I would replace the the thermal fuse, and the internal bias thermost. That is the one on the backside of blower housing. Tom
  #7 (permalink)
Old 05-25-2011, 05:25 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Here are your parts, a XSN0 does not show up but there is an XSN1.
Replacement parts for LE6150XSNO models | AppliancePartsPros.com
I am assuming that the fuse that keeps blowing is the thermal cutoff on the heater.
I would take a close look at the heating element for any signs (weld or scorch mark) that the element has touched the case.
Usually when an element touches the case it will weld itself to the case but perhaps as it is heating up it sags/deforms touches the case and then comes loose once it cools.
The hi-limit should control the temperature so that this fuse/cutoff does not blow so your problem has to be something that keeps the heater running and none of the thermostats can control it and that is usually a grounded element.
Check all wires going to the element to be sure one of them is not grounding out.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Heating element or thermal fuse? wortonmt Dishwasher Repair 9 08-08-2014 12:10 AM
maytag dryer blowing thermal fuse chavez107 Dryer Repair 2 04-20-2010 02:10 AM
Thermal fuse blowing M.C. Dryer Repair 2 02-09-2010 06:57 AM
Dryer thermal fuse keeps blowing pocketpet3500 Dryer Repair 3 08-19-2009 05:26 PM
Whirlpool dryer-thermal fuse keeps blowing needs help Dryer Repair 4 04-13-2009 03:48 PM
