| » electric dryer cold air only |
Model Number: eq2152es1 Brand: Frigidaire Age: 1 - 5 years
We have had our dryer 13 months and it shut off during a cycle and now only runs with cold air what is the problem with it??? and how easy is the repair for us to fix?
13 months sounds a little to early for a coil to go bad. I am suspecting a voltage problem. If you have a meter, you need to check the power at the plug, to be sure you have 240 volts. Just because the dryer runs, does not mean you have all the power. Try going outside to your breaker box, and flip the dryer breaker off and on a few times to be sure it is not partially tripped. Tom ********************************************
| Display Modes | |
| General Electric DBLR333ET0WW Electric dryer | pmkcreations | Dryer Repair | 0 | 05-18-2011 05:12 PM |
| Electric dryer will turn, blow cold air BUT not heat. | rolandvz71 | Dryer Repair | 5 | 01-31-2011 04:28 PM |
| Cold/Cold, Warm/Cold and Hot/Cold Button Settings do not trigger the Rinse cycles | ralphdisimone@gmail.com | Washer Repair | 1 | 10-12-2010 02:55 PM |
| Electric Burner Cold | scottfree | Oven Repair (including Ranges and Cooktops) | 1 | 09-07-2010 09:53 AM |
| Maytag electric over way too cold! | tigerpilot | Oven Repair (including Ranges and Cooktops) | 2 | 07-30-2007 05:53 PM |
