Discuss
whirlpool dryer will not start
 in
Dryer Repair
My whirlpool dryer would not start so I read some of the tips on some of the other postings and
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » whirlpool dryer will not start
  #1 (permalink)
Old 02-04-2009, 07:05 PM
Junior Member
bratsinc4 is on a distinguished road
Question whirlpool dryer will not start
Model Number: LEQ9858LW0   Brand: Whirlpool   Age: 5 - 10 years
My whirlpool dryer would not start so I read some of the tips on some of the other postings and saw that it is probably the thermal fuse, but it said that if you replace it then you should probably replace the operating thermostat at the same time. My question is that I have 3 different thermostats on my dryer. 1) thermostat, internal bias 2) thermal cut-off for heating element and 3) thermostat, fixed Which one is considered the operating thermostat? Thanks
Related Models
Whirlpool LEQ9858LW0 RESIDENTIAL DRYER
Whirlpool LEQ9858LW1 29"ELECTRIC DRYER
Whirlpool LEQ9858PG0 29"ELECTRIC DRYER
Whirlpool LEQ9858PG1 29"ELECTRIC DRYER
Whirlpool LEQ9858PW0 29"ELECTRIC DRYER
Whirlpool LEQ9858PW1 29"ELECTRIC DRYER
Whirlpool LEQ9957KQ0 RESIDENTIAL DRYER
Whirlpool LEQ9957KT0 RESIDENTIAL DRYER
Admiral LER1115AAW RANGE- F/S STD ELE
Whirlpool LER2614BW0 ELECTRIC DRYER
Whirlpool LER2614BW1 ELECTRIC DRYER
Whirlpool LER2614BW2 ELECTRIC DRYER
Whirlpool LER2614DW0 ELECTRIC DRYER
Whirlpool LER2614DW1 ELECTRIC DRYER
Whirlpool LER2614EW0 ELECTRIC DRYER
Whirlpool LER2614EW1 ELECTRIC DRYER
Whirlpool LER2614EW2 ELECTRIC DRYER
Whirlpool LER2614JQ0 ELECTRIC DRYER
Whirlpool LER2614JQ1 ELECTRIC DRYER
Whirlpool LER2614JQ2 29"ELECTRIC DRYER
Frigidaire LER331DS0 Frigidaire/dryer
Admiral LER3330AAB RANGE- S/C F/S ELE
Admiral LER3330AAW RANGE- S/C F/S ELE
Admiral LER3330AAZ RANGE- S/C F/S ELE
Whirlpool LER3422AW0 Residential Dryer
Whirlpool LER3424AW0 Residential Dryer
Whirlpool LER3622BN0 COMPACT ELECTRIC DRYER
Whirlpool LER3622BW0 COMPACT ELECTRIC DRYER
Whirlpool LER3622DQ1 COMPACT ELECTRIC DRYER
Whirlpool LER3622DQ2 COMPACT ELECTRIC DRYER
Whirlpool LER3622DZ1 COMPACT ELECTRIC DRYER
Whirlpool LER3622DZ2 COMPACT ELECTRIC DRYER
Whirlpool LER3622HQ0 DRYER
Whirlpool LER3622HQ1 RESIDENTIAL DRYER
Whirlpool LER3622PQ0 COMPACT ELECTRIC DRYER
Whirlpool LER3622PQ1 COMPACT ELECTRIC DRYER
Whirlpool LER3622PQ2 COMPACT ELECTRIC DRYER
Whirlpool LER3624BN2 ELECTRIC DRYER
Whirlpool LER3624BN3 ELECTRIC DRYER
Whirlpool LER3624BW0 ELECTRIC DRYER
Whirlpool LER3624BW1 ELECTRIC DRYER
Whirlpool LER3624BW2 ELECTRIC DRYER
Whirlpool LER3624BW3 ELECTRIC DRYER
Whirlpool LER3624DQ0 DRYER
Whirlpool LER3624DQ1 ELECTRIC DRYER
Whirlpool LER3624DQ2 ELECTRIC DRYER
Whirlpool LER3624DZ0 DRYER
Whirlpool LER3624DZ2 ELECTRIC DRYER
Whirlpool LER3624EQ0 LAUNDRY DRYERS
Whirlpool LER3624EQ1 ELECTRIC DRYER
Whirlpool LER3624JQ0 DRYER
Whirlpool LER3624JQ1 RESIDENTIAL DRYER
Whirlpool LER3624JQ2 29" ELECTRIC DRYER
Whirlpool LER3624PQ0 29" ELECTRIC DRYER
Whirlpool LER3624PQ1 29" ELECTRIC DRYER
Whirlpool LER3634EW0 ELECTRIC DRYER
Whirlpool LER3634EW1 DRYERS
Whirlpool LER3634EW2 ELECTRIC DRYER
Whirlpool LER3634JW0 ELECTRIC DRYER
Whirlpool LER3634JW1 RESIDENTIAL DRYER
Admiral LER3725AAC RANGE- S/C F/S ELE
Whirlpool LER4434AN0 ELECTRIC DRYER
Whirlpool LER4434AN1 ELECTRIC DRYER
Whirlpool LER4434AQ0 Residential Dryer
Whirlpool LER4434AQ1 ELECTRIC DRYER
Whirlpool LER4434AW0 Residential Dryer
Whirlpool LER4434AW1 ELECTRIC DRYER
Whirlpool LER4436AW0 Residential Dryer
Whirlpool LER4600PQ0 29" ELECTRIC DRYER
Whirlpool LER4600PQ1 29" ELECTRIC DRYER
Whirlpool LER4624BN0 ELECTRIC DRYER
Whirlpool LER4624BN1 ELECTRIC DRYER
Whirlpool LER4624BN2 ELECTRIC DRYER
Whirlpool LER4624BQ0 ELECTRIC DRYER
Whirlpool LER4624BQ1 ELECTRIC DRYER
Whirlpool LER4624BQ2 ELECTRIC DRYER
Whirlpool LER4624BW0 ELECTRIC DRYER
Whirlpool LER4624BW1 ELECTRIC DRYER
Whirlpool LER4624BW2 ELECTRIC DRYER
Whirlpool LER4624DQ0 ELECTRIC DRYER
Whirlpool LER4624DQ1 ELECTRIC DRYER
Whirlpool LER4624DZ0 ELECTRIC DRYER
Whirlpool LER4624DZ1 ELECTRIC DRYER
Whirlpool LER4634BQ0 ELECTRIC DRYER
Whirlpool LER4634BQ1 ELECTRIC DRYER
Whirlpool LER4634BQ2 ELECTRIC DRYER
Whirlpool LER4634DQ0 DRYERS
Whirlpool LER4634DQ1 ELECTRIC DRYER
Whirlpool LER4634DZ0 DRYERS
Whirlpool LER4634DZ1 ELECTRIC DRYER
Whirlpool LER4634EQ0 ELECTRIC DRYER
Whirlpool LER4634EQ1 DRYERS
Whirlpool LER4634EQ2 ELECTRIC DRYER
Whirlpool LER4634EW0 ELECTRIC DRYER
Whirlpool LER4634EZ0 ELECTRIC DRYER
Whirlpool LER4634EZ1 DRYERS
Whirlpool LER4634EZ2 ELECTRIC DRYER
Whirlpool LER4634JQ0 ELECTRIC DRYER
Whirlpool LER4634JQ1 RESIDENTIAL DRYER
Whirlpool LER4634JQ2 29" ELECTRIC DRYER
Whirlpool LER4634JT0 ELECTRIC DRYER
Whirlpool LER4634JT1 RESIDENTIAL DRYER
Whirlpool LER4634JT2 29" ELECTRIC DRYER
Whirlpool LER4634JZ0 ELECTRIC DRYER
Whirlpool LER4634PQ0 29" ELECTRIC DRYER
Whirlpool LER4634PQ1 29" ELECTRIC DRYER
Whirlpool LER4634PT0 29" ELECTRIC DRYER
Whirlpool LER4634PT1 29" ELECTRIC DRYER
Whirlpool LER5434AW0 Residential Dryer
Whirlpool LER5600HQ0 ELECTRIC DRYER
Whirlpool LER5600HZ0 ELECTRIC DRYER
Whirlpool LER5600JQ0 ELECTRIC DRYER
Whirlpool LER5600JT0 ELECTRIC DRYER
Whirlpool LER5620KQ0 RESIDENTIAL DRYER
Whirlpool LER5620KQ1 ELECTRIC DRYER
Whirlpool LER5620KQ2 29"ELECTRIC DRYER
Whirlpool LER5624BN0 ELECTRIC DRYER
Whirlpool LER5624BN1 ELECTRIC DRYER
Whirlpool LER5624BN2 ELECTRIC DRYER
Whirlpool LER5624BW0 ELECTRIC DRYER
  #2 (permalink)
Old 02-05-2009, 02:35 AM
Senior Expert
APP Volunteer
kayakcrzy will become famous soon enough
Default
You are right about the thermal fuse, and the thermostat being changed at the same time, but that is not your problem. In the back the is another thermal fuse. It is white in color, and about an inch and a half long, by a half inch wide, and has 2 wires coming to it, and it is held in by 1 screw. That is most likely the problem. If not, it would be a door switch, or a bad breaker. Tom ********************************************
  #3 (permalink)
Old 02-06-2009, 06:52 PM
Junior Member
Talking Thanks Tom!
Tom
Thanks so much for your help I ordered the thermal fuse, replaced it and now my dryer is working like a charm! I live in the country and if I would have had to have a repair guy out it would have cost me a fortune, but with your help I was able to fix it myself! Thanks again!
Stacey
  #4 (permalink)
Old 02-07-2009, 05:04 AM
Senior Expert
APP Volunteer
Default
Thanks you so much for letting me know. Good Job!!! Glad to have saved you the money. Tom ********************************************
  #5 (permalink)
Old 09-08-2011, 06:21 PM
Junior Member
pshisbey is on a distinguished road
Default New thermal fuse fixed mine to
My whirlpool drier wouldn't start either. Replaced the thermal fuse ($25 later) and it runs as good as new. Very easy to replace! Thank you Tom and Sacey!
I used the following links
http://www.whirlpool.com
Appliance Parts from WhirlpoolPartsOnline.com
Phil
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool gas dryer won't start sewqueen Dryer Repair 17 01-06-2012 08:30 AM
whirlpool dryer will not start dafense Dryer Repair 2 02-11-2010 10:01 AM
Whirlpool Dryer will not start mbryans Dryer Repair 9 01-17-2010 04:39 PM
Whirlpool dryer won't start hockey Dryer Repair 4 11-16-2009 07:16 AM
whirlpool dryer will not start rsqmedic8 Dryer Repair 1 07-27-2009 10:14 AM
