| » Kenmore electric dryer 70 series won't run |
Model Number: 110.66712692 Brand: Kenmore Age: 5 - 10 years
My husband overloaded the dryer and now it won't run. When you press the on button, it makes about 2 revolutions and then stops. You can also smell the heating element when doing this. The drum gives resistance when turned manually. How do we diagnose the problem so we can replace the broken part?
The problem is the the husband on this one. Actually, it needs a motor. Tom ********************************************
the only other thing to check is to see if something did not fall into the blower wheel. take the back off the dryer, and if you are behind it on the left hand side is where the filter goes in. there are four 5/16s screws holding it in place. take those off, and also pull the lint filter out, and remove the 2 phillip head screws, and then slide the cover to the right, and it will expose the blower wheel. check it out, and let me know. tom ******************************************** - parts
It still sounds like the motor to me. If the belt looks worn replace it too. Tom ********************************************
It is wraped around the drum. Look how it goes on, before you take it off. Rib side down. Tom ********************************************
| Display Modes | |
| Kenmore 70 Series Electric Dryer Squeals | citizen01 | Dryer Repair | 1 | 10-24-2009 11:21 PM |
| Kenmore dryer 80 series | jinks7 | Dryer Repair | 1 | 07-09-2009 02:52 PM |
| Kenmore HD 70 Series Electric Dryer | jeneric | Dryer Repair | 1 | 03-02-2009 03:02 PM |
| Kenmore 70 series electric dryer does not make a sound | Medamida | Dryer Repair | 1 | 12-11-2008 09:37 AM |
| Sears 80 Series Electric Dryer | gilbrooks | Dryer Repair | 3 | 10-28-2008 01:51 PM |
