Discuss
dryer runs for a while then all electric stops.
 in
Dryer Repair
Dryer will run and then it just stops. When you open dryer door no light no electric. After a while
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » dryer runs for a while then all electric stops.
  #1 (permalink)
Old 02-03-2009, 08:23 PM
Junior Member
Bill Lewis is on a distinguished road
Default dryer runs for a while then all electric stops.
Model Number: ler862opwo   Brand: Whirlpool   Age: 1 - 5 years
Dryer will run and then it just stops. When you open dryer door no light no electric. After a while you can hit the start botton and it will run.. Help
Related Models
Whirlpool LER8648LG0 RESIDENTIAL DRYER
Whirlpool LER8648LG1 29"ELECTRIC DRYER
Whirlpool LER8648LQ0 RESIDENTIAL DRYER
Whirlpool LER8648LW0 RESIDENTIAL DRYER
Whirlpool LER8648LW1 29"ELECTRIC DRYER
Whirlpool LER8648PG0 29"ELECTRIC DRYER
Whirlpool LER8648PG1 29"ELECTRIC DRYER
Whirlpool LER8648PQ0 29" ELECTRIC DRYER
Whirlpool LER8648PQ1 29"ELECTRIC DRYER
Whirlpool LER8648PW0 29"ELECTRIC DRYER
Whirlpool LER8648PW1 29"ELECTRIC DRYER
Whirlpool LER8857EQ0 ELECTRIC DRYER
Whirlpool LER8857EQ1 DRYERS
Whirlpool LER8857EQ2 ELECTRIC DRYER
Whirlpool LER8857EZ0 ELECTRIC DRYER
Whirlpool LER8857EZ1 DRYERS
Whirlpool LER8857EZ2 ELECTRIC DRYER
Whirlpool LER8858DQ0 ELECTRIC DRYER
Whirlpool LER8858DQ1 ELECTRIC DRYER
Whirlpool LER8858DZ0 ELECTRIC DRYER
Whirlpool LER8858DZ1 ELECTRIC DRYER
Whirlpool LER8858EQ0 ELECTRIC DRYER
Whirlpool LER8858EQ1 DRYERS
Whirlpool LER8858EQ2 ELECTRIC DRYER
Whirlpool LER8858EZ0 ELECTRIC DRYER
Whirlpool LER8858EZ1 DRYERS
Whirlpool LER8858EZ2 ELECTRIC DRYER
Whirlpool LER8875EQ1 ELECTRIC DRYER
Amana LES10AW WASHER-TOP LOADING
Amana LES19AW DRYER- GAS
Amana LES33AW DRYER- GAS
Amana LES34AW WASHER-TOP LOADING
Frigidaire LES389FEA Frigidaire/electric Range
Frigidaire LESR26EFE0 Frigidaire/refrigerator
Frigidaire LESR26EFE3 REFRIGERATOR
Frigidaire LESR26EFE4 REFRIGERATOR
Frigidaire LESR26EFE5 REFRIGERATOR
Frigidaire LESR26EFE6 REFRIGERATOR
Frigidaire LESR26EFE7 REFRIGERATOR
Whirlpool LET5434AQ0 Residential Dryer
Whirlpool LET5434AW0 Residential Dryer
Whirlpool LET5436AW0 Residential Dryer
Whirlpool LET5624BN0 ELECTRIC DRYER
Whirlpool LET5624BN1 ELECTRIC DRYER
Whirlpool LET5624BN2 ELECTRIC DRYER
Whirlpool LET5624BQ0 ELECTRIC DRYER
Whirlpool LET5624BQ1 ELECTRIC DRYER
Whirlpool LET5624BQ2 ELECTRIC DRYER
Whirlpool LET5624BW0 ELECTRIC DRYER
Whirlpool LET5624BW1 ELECTRIC DRYER
Whirlpool LET5624BW2 ELECTRIC DRYER
Whirlpool LET5624DQ0 ELECTRIC DRYER
Whirlpool LET5624DQ1 DRYER
Whirlpool LET6634AN1 ELECTRIC DRYER
Whirlpool LET6634AN2 ELECTRIC DRYER
Whirlpool LET6634AQ0 ELECTRIC DRYER
Whirlpool LET6634AQ1 ELECTRIC DRYER
Whirlpool LET6634AQ2 ELECTRIC DRYER
Whirlpool LET6634AW0 Residential Dryer
Whirlpool LET6634AW1 ELECTRIC DRYER
Whirlpool LET6634AW2 ELECTRIC DRYER
Whirlpool LET6634DQ0 ELECTRIC DRYER
Whirlpool LET6634DQ1 ELECTRIC DRYER
Whirlpool LET6634DZ0 ELECTRIC DRYER
Whirlpool LET6634DZ1 ELECTRIC DRYER
Whirlpool LET6638AN1 DRYER
Whirlpool LET6638AN2 ELECTRIC DRYER
Whirlpool LET6638AQ2 ELECTRIC DRYER
Whirlpool LET6638AW0 Residential Dryer
Whirlpool LET6638AW1 DRYER
Whirlpool LET6638AW2 ELECTRIC DRYER
Whirlpool LET6638DQ0 ELECTRIC DRYER
Whirlpool LET6638DQ1 ELECTRIC DRYER
Whirlpool LET6638DZ0 ELECTRIC DRYER
Whirlpool LET6638DZ1 ELECTRIC DRYER
Whirlpool LET7646AQ0 Residential Dryer
Whirlpool LET7646AQ1 ELECTRIC DRYER
Whirlpool LET7646AQ2 ELECTRIC DRYER
Whirlpool LET7646AW0 Residential Dryer
Whirlpool LET7646AZ1 ELECTRIC DRYER
Whirlpool LET7646AZ2 ELECTRIC DRYER
Whirlpool LET7646DQ0 ELECTRIC DRYER
Whirlpool LET7646DQ1 ELECTRIC DRYER
Whirlpool LET7646DZ0 ELECTRIC DRYER
Whirlpool LET7646DZ1 ELECTRIC DRYER
Whirlpool LET7646EQ0 ELECTRIC DRYER
Whirlpool LET7646EQ1 DRYERS
Whirlpool LET7646EQ2 ELECTRIC DRYER
Whirlpool LET7646EZ0 ELECTRIC DRYER
Whirlpool LET7646EZ1 DRYERS
Whirlpool LET7646EZ2 ELECTRIC DRYER
Whirlpool LET7848AQ0 Residential Dryer
Whirlpool LET7848AQ1 ELECTRIC DRYER
Whirlpool LET7848AQ2 ELECTRIC DRYER
Whirlpool LET7848AW0 Residential Dryer
Whirlpool LET7848AZ1 ELECTRIC DRYER
Whirlpool LET7848AZ2 ELECTRIC DRYER
Whirlpool LET7848DQ0 ELECTRIC DRYER
Whirlpool LET7848DQ1 ELECTRIC DRYER
Whirlpool LET7848DZ0 ELECTRIC DRYER
Whirlpool LET7848DZ1 ELECTRIC DRYER
Whirlpool LET8858AN1 ELECTRIC DRYER
Whirlpool LET8858AN2 ELECTRIC DRYER
Whirlpool LET8858AQ0 ELECTRIC DRYER
Whirlpool LET8858AQ1 ELECTRIC DRYER
Whirlpool LET8858AQ2 ELECTRIC DRYER
Whirlpool LET8858AW0 Residential Dryer
Whirlpool LET8858AW1 ELECTRIC DRYER
Whirlpool LET8858AW2 ELECTRIC DRYER
Whirlpool LET8858AZ0 ELECTRIC DRYER
Whirlpool LET8858AZ1 ELECTRIC DRYER
Whirlpool LET8858AZ2 ELECTRIC DRYER
Whirlpool LET8858DQ0 ELECTRIC DRYER
Whirlpool LET8858DQ1 ELECTRIC DRYER
Whirlpool LET8858DZ0 ELECTRIC DRYER
Whirlpool LET8858DZ1 ELECTRIC DRYER
Amana LEU108 RANGE- S/C S/I DDRAFT GAS
Whirlpool LEV4434AW0 Residential Dryer
Whirlpool LEV4436AW0 Residential Dryer
Whirlpool LEV4624BG0 ELECTRIC DRYER
  #2 (permalink)
Old 02-04-2009, 07:04 AM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
Sounds like the connections are eroded or loose. First, check the power coming from the outlet. Then check the connections at the wiring terminal. (Don't touch them unless the dryer is unplugged).
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer runs for 30 seconds and stops vbodin310 Dryer Repair 1 01-24-2010 07:23 AM
dryer runs then stops before cycle is over cobra9646 Dryer Repair 4 10-21-2008 07:35 AM
Dryer runs 5 min. and stops chuckman Dryer Repair 2 08-14-2008 06:14 PM
Gas Dryer Runs but Heat Stops Working terrib Dryer Repair 1 12-26-2007 03:37 PM
dryer runs then stops mike_T Dryer Repair 0 09-04-2007 05:41 AM
