| » Gas dryer won't heat |
Model Number: DG608 Brand: Maytag Age: More than 10 years
Gas dryer won't heat up. This occured just on a normal day of washing.
Can you tell me what part and the part number is to repair? Ads By Google Related Models |
When a gas dryer just stops heating out of the blue the first thing I check is the the ignitor ... Here is a video that shows how thats done ... Keep me informed on what you find YouTube - ‪Dryer Igniter Testing‬‏
__________________
Case Appliance Repair College Station,Texas- |
Here are the components involved in the heating circuit in your dryer: The timer; thermostats; igniter; radiant sensor (also called a "flame sensor"); gas valve coils.
You need to systematically check each one of these components, so that you don't waste money on unnecessary parts purchaces. You can eliminate some of this testing by observing the igniter. Does it glow, when you have the dryer set in a heat mode? You may be able to see the glow from under the dryer, if you can darken the room. If you do see a glowing igniter, you can surmise that the timer and thermostats are working properly. Tell us what you find. |
| Display Modes | |
| Roper (Gas) Dryer heats up then heat goes off (still running, no heat) | jtdesignsca | Dryer Repair | 3 | 01-17-2013 12:06 PM |
| gas dryer only heats on perm press and low heat, but not on high heat? | GrandCanyonEngineer | Dryer Repair | 0 | 03-02-2011 02:23 PM |
| Kenmore dryer heats on low heat but not on high heat | Mrhollywood334 | Dryer Repair | 0 | 09-11-2010 09:33 PM |
| Clothes dryer runs, but doest not heat (Dryer no heat | yzhong | Dryer Repair | 5 | 10-29-2009 04:54 PM |
| Dryer will not heat. It tumbles and cycles but it will not emit any heat. | agentsmith0505 | Dryer Repair | 0 | 10-14-2009 09:44 AM |
