Discuss
General Electric DBLR333ET0WW Electric dryer
 in
Dryer Repair
I have this dryer and have just replaced the thermostat that mounts on the back of the drum assembly. Here
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » General Electric DBLR333ET0WW Electric dryer
  #1 (permalink)
Old 05-18-2011, 05:12 PM
Junior Member
pmkcreations is on a distinguished road
Default General Electric DBLR333ET0WW Electric dryer
Brand: GE   Age: More than 10 years
Here has been the problem:
In either the Automatic Cottons or Automatic Permanent Press cycles the dryer wants to keep running for very long times before the items actually dry. Some times it runs so long that the clothes are actually slightly shrunk when it finally finishes. Towels are the absolute worst and take forever to dry. The timer does move when I use the timed cycle and when the dryer is fairly empty it seems to run fine and dry okay. It seems the more that is filling the dryer the harder it is to get a happy medium with the automatic cycles. Also, I have had this apart and there are no blockages from lint. And I know that the elements do heat.
Any suggestions on what I can check next?
Ads By Google
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
General Electric dryer part needed MK7 Dryer Repair 0 09-28-2010 06:07 PM
General Electric Help GlassPaper Washer Repair 1 12-10-2009 06:19 PM
General Electric Terry Peters Dishwasher Repair 1 03-02-2009 01:19 PM
General Electric dryer won't heat up rod_44 Dryer Repair 5 08-10-2008 03:47 PM
general electric dryer won't start adrianbolso77 Dryer Repair 4 01-29-2008 06:25 PM
