Appliance Repair Forum
-   Dryer Repair (http://forum.appliancepartspros.com/dryer-repair/)
-   -   Kenmore Dryer wont start (http://forum.appliancepartspros.com/dryer-repair/22437-kenmore-dryer-wont-start.html)
rrhoward78 02-01-2009 07:50 AM
Help please. I did laundry yesterday and my dryer worked fine! Today when i loaded it up, I pressed start. it hummed like it wanted to work, but it didn't turn. Then it started to smell bad. I unplugged it. :confused:
I popped the top up and looked around and found nothing. The drum can manually be turned without any problems. I had my daughter hold the button so it thought the door was closed and I pushed start and spun the drum myself. it started, but it was very slow and kept making a clicking sound like it was about to shut off. :eek:
Is it the motor? a pulley? I am lost here! Please help!!!!! :( I've had this dryer for 10 years, is it just time to buy a new one? or is it worth fixing? I haven't had any problems with it before.
denman 02-01-2009 09:11 AM
Yes, it does sound like the motor is toast.
Call or email here for the price of a new motor, probably around $100.00
Also check your belt, rear rollers ,front glides, idler wheel etc. for signs of wear and bearing slop. Then you will have a better idea what the total cost will be.
rrhoward78 02-01-2009 12:05 PM
thanks!
I figured it was pretty much dead from the smell it made! i was hoping it was just the belt, but the belt is fully intact and the drum turns with ease! thanks for your help!!! :)
