| » Dryer not heating |
Model Number: wed6200sw0 Brand: Maytag Age: 1 - 5 years
My electric dryer is does not heating up. I have checked the circuit breaker and they are not tripped. I have also unpluged it for 24 hrs and still no heat.
gary, it is either the element or the thermal fuse, mounted on the top left side of the element housing. if you have a ohm meter, unplug the dryer, and ohm it out. make sure you pull the wires off of either part when you ohm it out. tom ******************************************** - parts
When you checked your breaker did you just look at it or did you turn it off then back on. Often if you loose half the line it will not trip the breaker.
Best way is to check with a meter to ensure you have 240 volts.
__________________
| Display Modes | |
| Dryer not heating | rcabalo | Dryer Repair | 2 | 11-26-2009 09:52 AM |
| dryer not heating | iyacko | Dryer Repair | 2 | 08-26-2009 12:50 PM |
| dryer not heating | ecubulldog | Dryer Repair | 1 | 07-05-2009 07:40 AM |
| Dryer not Heating | stompy27 | Dryer Repair | 0 | 11-05-2008 06:06 AM |
| Gas dryer not heating | Penthor | Dryer Repair | 3 | 02-17-2008 08:56 AM |
