Auto sense and high heat timed dry, not drying, it starts off great it heats up for a few minutes and than all cold air, timer does not move also and it would run for 4-5 hours and not dry, I put a new timer on it, same problem, is there a sensor, could this be? It dryes in low heat timed dry, it takes 3,4 times.
Please help. Thanx.
