wwwpol
#1 Posted : Thursday, January 29, 2009 12:14:42 PM(UTC)
wwwpol
I replaced the timer with a new one, but the timer won't advance. Heat comes on and it works other wise. But it runs forever.
This dryer has a moisture sensor on it. I wonder if it is bad and doesn't tell the timer to advance?
The timer might be bad as well. They are sending me a new one.
Any ideas? What else could it be if I put in a new timer?
#2 Posted : Thursday, January 29, 2009 1:43:36 PM(UTC)
Here is your parts
Model LEN2000JQ1
Here is a wiring diagram with a timing chart
https://www.servicematters.com/d...0Sheet%20-%208299793.pdf
Does the timer advance in Timed Dry mode.
It uses a different circuit path than Auto.
wwwpol
#3 Posted : Friday, January 30, 2009 7:47:05 AM(UTC)
wwwpol
The timer does work in timed dry mode. I should have checked that. We always use the accudry mode which checks the moisture. So is there a moisture sensor that I need to change? Sounds like the timer is fine.
#4 Posted : Friday, January 30, 2009 12:00:33 PM(UTC)
In the parts link the:
Moisture sensor is Item 30 in Section 3
Electronic Control Board is Item 51 in Section 2
It will probably be one of the above that is the cause.
Clean the face of the moisture sensor. Make sure it is good and dry before testing.
If this does not fix it, disconnect the moisture sensor
If this does not fix it, it is probably the circuit board
Whirlpool Dryer - Timer Won't Advance in Auto (Dryer Repair)
by AMarkham40 12/10/2016 11:18:39 AM(UTC)
Is it safe to run dryer if timer won't advance? (Dryer Repair)
by Living 7/7/2015 7:22:15 PM(UTC)
GE Dryer Timer Won't Advance (Dryer Repair)
by tmhmah4 3/9/2015 5:09:49 PM(UTC)
roper dryer timer won't advance (Dryer Repair)
by jwb1977 7/10/2014 2:28:36 PM(UTC)
Maytag dryer timer won't advance during cycle (Dryer Repair)
by baseeight 1/24/2014 10:16:44 AM(UTC)
Kenmore - timer won't advance even with replacement (Dryer Repair)
by vickischow 8/6/2013 11:10:28 AM(UTC)
whirlpool dryer not heatting and timer won't advance (Dryer Repair)
by vero_09 11/8/2012 4:03:48 AM(UTC)
Series 80 Kenmore washer timer won't advance (Washer Repair)
by frugalastheyget 7/27/2012 11:27:28 AM(UTC)
HELP! Dryer will not shut off & timer won't advance (Dryer Repair)
by csutliff 4/11/2012 10:17:10 AM(UTC)
Timer won't advance in auto modes (Dryer Repair)
by sly1types 10/17/2011 2:29:33 PM(UTC)
Maytag dryer timer won't advance (Dryer Repair)
by Boolala 5/25/2011 8:09:41 AM(UTC)
Timer won't advance (Dryer Repair)
by moeenzo 12/29/2010 8:30:15 PM(UTC)
Timer won't advance (Washer Repair)
by sheilakn 12/29/2010 2:44:35 PM(UTC)
Timer Won't Advance (Washer Repair)
by Scs8104 12/27/2010 8:25:46 AM(UTC)
Washer timer won't advance (Washer Repair)
by jbuckingham 9/20/2010 6:26:48 AM(UTC)
