| » Looking for thermostat |
If I use the 3388011 number this is what comes up.
WHIRLPOOL 3388011 Panel - control, AP2912986 | AppliancePartsPros.com Check the listed dryers to see if any of them match your unit. Perhaps the following will help you find the model number tag. Model Number Locator i check voltage and everything had except for the thermostat I cannot comment on the above as you did not say what/where exactly you were measuring. You are better off unplugging the unit and one side of the thermostat, then checking it with a meter using resistance. All thermostats should be 0 ohms.
__________________
Section replacement parts for WHIRLPOOL LE5700XSW0 Residential Dryer | AppliancePartsPros.com See the attachment for a wiring diagram Note: It is for a 6LE5700 not a LE5700 but hopefully it will be close to yours. If you do not have the actual wiring diagram take a look in the control console often there is a diagram in there.
__________________
| Display Modes | |
| Replace high limit thermostat a or cycling thermostat along with the thermal fuse? | BrassMonkey | Dryer Repair | 1 | 11-15-2010 06:23 PM |
| thermostat | rayo | Oven Repair (including Ranges and Cooktops) | 0 | 07-02-2010 07:04 PM |
| TOD Thermostat fix | rmlong | Oven Repair (including Ranges and Cooktops) | 0 | 02-23-2010 11:54 AM |
| thermostat | franko | Oven Repair (including Ranges and Cooktops) | 1 | 01-19-2010 11:55 PM |
| bought new thermostat and heater thermostat and now won't heat at all | mgilbert6 | Dryer Repair | 0 | 09-07-2008 09:58 AM |
