Frigidaire gas dryer turns on, ignites, then seems to get up to temp, heat kicks off and doesn't re ignite. In the automatic mode, the knob doesn't advance. In timed dry, it does same thing but knob does advance. I can't see the igniter directly to see if it is glowing properly. I was thinking of getting new igniter and gas valve kit because when I tear it apart, I want to have the stuff right there to put it back together again. Am I on the right track????
