| » Estate Dryer by Whirlpool/Dryer running but no heat |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: TEDS7U0PQ0 Brand: Estate Age: 1 - 5 years
My timer is working, unfortunately my dryer is not getting hot. I took the dryer apart to locate the heating element, because I thought that may be the problem. After reading majority of the posts I am not sure. Do I have to get a multi-meter to check the coils and see if it is 'open', also do I have to check the elements under the control panel.
I ruled them out because that works just the dryer is not getting hot. If I have to check the Thermal Cut-off and the Thermal Fuse, please let me know where it is located. Thank You, Tiona |
I'm not seeing any online data on this particular model but check the incoming voltage to this dryer and make sure it's 220-240 volts... A worn receptacle or plug can affect one of the hot legs providing power to the 110V motor but not the 220 volt heating elements... A faulty circuit breaker or burnt wire connection where the plug wires connect to the dryer will cause this condition as well... Good luck, kooler
__________________
| Display Modes | |
| Whirlpool dryer won't stop running | dryrprob | Dryer Repair | 5 | 11-04-2007 02:38 AM |
| Whirlpool Dryer Estate | 4018 | Dryer Repair | 1 | 10-23-2007 02:34 AM |
| Whirlpool gas dryer runs but no heat | c1gia | Dryer Repair | 0 | 08-14-2007 08:26 PM |
| Whirlpool Dryer - No heat | Warren | Dryer Repair | 0 | 08-14-2007 03:30 PM |
| Whirlpool dryer heat shuts off | Captain Carquest | Dryer Repair | 0 | 08-09-2007 11:37 AM |
