| » dryer won't heat |
Could be a number of things but the first thing to check is the power.
Otherwise you could waste hours ripping the unit apart and checking things without any luck. The motor, light etc. run off of 120 but the heating coil requires 240. Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker. If this does nothing, check the voltage at the plug L1 to L2 should be 240 volts L1 to Neutral and L2 to Neutral, both should be 120 volts. If OK Unplug the unit and check the wires at the terminal strip in the machine to make sure none are loose or burned out If OK Check the power at the terminal strip. Be careful as 240 volts is lethal !!! Next would be to unplug the unit and check the thermostats. If you do not own a meter, I would suggest you purchase a one. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long. If it saves ordering one unnecessary part it has paid for itself and you end up owning a useful tool. Most places will not let you return electrical parts so if you order it, you own it. A couple things to watch when measuring ohms and continuity 1. Always remove power from the machine otherwise you could blow your meter. 2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path. 3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale's dynamic range. There is a good STICKY at the start of this forum about it's use.
__________________
| Display Modes | |
| Roper (Gas) Dryer heats up then heat goes off (still running, no heat) | jtdesignsca | Dryer Repair | 3 | 01-17-2013 12:06 PM |
| gas dryer only heats on perm press and low heat, but not on high heat? | GrandCanyonEngineer | Dryer Repair | 0 | 03-02-2011 02:23 PM |
| Dryer stops after a few minutes with heat on - will run continuously with heat off | somegeek | Dryer Repair | 0 | 05-27-2010 01:35 PM |
| Clothes dryer runs, but doest not heat (Dryer no heat | yzhong | Dryer Repair | 5 | 10-29-2009 04:54 PM |
| Dryer will not heat. It tumbles and cycles but it will not emit any heat. | agentsmith0505 | Dryer Repair | 0 | 10-14-2009 09:44 AM |
