My dryer initially heats when started, then...no heat. Trying to figure out which part I need to replace.:confused:
I have a gas dryer that would heat up once and then keep running but not heating. I replaced the flame sensor, ignitor, cycle thermostat and had the same problem. It turned out to be the gas valve coils. $14 and shipping. Too bad I didn't try that first. Hope it helps
